Compiling Firmware in Windows - Cannot install dependencies
TickTock
(@ticktock)
I am following the steps for setting up Visual Studio here:
https://github.com/prusa3d/Prusa-Firmware#windows
Fresh install, latest version of VS, CMake, Python, Bash
Everything goes well until the point I am to install dependencies via the python commad:
    python .\utils\bootstrap.py
I get the following error:
PS C:\prusa\Prusa-Firmware> python .\utils\bootstrapnv.pyDownloading cmake-3.22.5Traceback (most recent call last): File "C:\Python\lib\urllib\request.py", line 1317, in do_open h.request(req.get_method(), req.selector, req.data, headers, File "C:\Python\lib\http\client.py", line 1230, in request self._send_request(method, url, body, headers, encode_chunked) File "C:\Python\lib\http\client.py", line 1276, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "C:\Python\lib\http\client.py", line 1225, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "C:\Python\lib\http\client.py", line 1004, in _send_output self.send(msg) File "C:\Python\lib\http\client.py", line 944, in send self.connect() File "C:\Python\lib\http\client.py", line 1399, in connect self.sock = self._context.wrap_socket(self.sock, File "C:\Python\lib\ssl.py", line 500, in wrap_socket return self.sslsocket_class._create( File "C:\Python\lib\ssl.py", line 1040, in _create self.do_handshake() File "C:\Python\lib\ssl.py", line 1309, in do_handshake self._sslobj.do_handshake()ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certific
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File ".\utils\bootstrapnv.py", line 199, in <module> sys.exit(main()) File ".\utils\bootstrapnv.py", line 182, in main install_dependency(dependency) File ".\utils\bootstrapnv.py", line 137, in install_dependency download_and_unzip(url=url, directory=installation_directory) File ".\utils\bootstrapnv.py", line 82, in download_and_unzip f, _ = urlretrieve(url, filename=None) File "C:\Python\lib\urllib\request.py", line 247, in urlretrieve with contextlib.closing(urlopen(url, data)) as fp: File "C:\Python\lib\urllib\request.py", line 222, in urlopeno_open raise URLError(err)urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1108)> PS C:\prusa\Prusa-Firmware>
Did some digging and found the fix for this, apparently, is to upgrade the cert in the python install directory:
pip install --upgrade certifi
I did this and it indicates success.  However, I get the same certificate has expired message when I run the bootstrap.py.  Attempting to upgrade the certificate again results in a message that the certificate has already been updated.
I don't know where to go from here.  Any suggestions would be welcome.
Napsal : 25/01/2025 7:26 pm
TickTock
(@ticktock)
RE: Compiling Firmware in Windows - Cannot install dependencies
OK.  I finally found a solution.  Going to leave here for anyone else who encounter this.  Add the following to the bootstrap.py file:
It should be noted that this bypasses the ssl security...
import urllib.request
import ssl
# Create an unverified SSL context
ssl._create_default_https_context = ssl._create_unverified_context
Napsal : 26/01/2025 12:33 pm
_KaszpiR_
(@_kaszpir_)
maybe there is an old certifi package in the virtualenv, thus upgrading system level package is not enough.
This should be reported as GitHub issue.
Napsal : 26/01/2025 3:24 pm
miroslav.h4
(@miroslav-h4)
When trying to compile the FW for MK4 I get the following output (the FW is without any modifications on my part, it's just a test to see if it will work):
C:\prusa\Buddy>python utils/build.py --preset mk4
Collecting aiohttp~=3.8 (from -r C:\prusa\Buddy\requirements.txt (line 1)) Using cached aiohttp-3.11.11-cp313-cp313-win_amd64.whl.metadata (8.0 kB)
Collecting click~=8.1.3 (from -r C:\prusa\Buddy\requirements.txt (line 2))
Using cached click-8.1.8-py3-none-any.whl.metadata (2.3 kB)
Collecting easyocr~=1.7 (from -r C:\prusa\Buddy\requirements.txt (line 3))
Using cached easyocr-1.7.2-py3-none-any.whl.metadata (10 kB)
Collecting ecdsa~=0.18 (from -r C:\prusa\Buddy\requirements.txt (line 4))
Using cached ecdsa-0.19.0-py2.py3-none-any.whl.metadata (29 kB)
Collecting littlefs-python==0.8 (from -r C:\prusa\Buddy\requirements.txt (line 5))
Using cached littlefs-python-0.8.0.tar.gz (480 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting nanobind~=1.9 (from -r C:\prusa\Buddy\requirements.txt (line 6))
Using cached nanobind-1.9.2-py3-none-any.whl.metadata (1.4 kB)
Collecting numpy==1.26.4 (from -r C:\prusa\Buddy\requirements.txt (line 7))
Using cached numpy-1.26.4.tar.gz (15.8 MB)
Installing backend dependencies: started
Installing backend dependencies: finished with status 'done'
Preparing metadata (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
Preparing metadata (pyproject.toml) did not run successfully.
exit code: 1
File "C:\prusa\Buddy\utils\build.py", line 837, in <module>
main()
File "C:\prusa\Buddy\utils\build.py", line 798, in main
bootstrap.bootstrap()
File "C:\prusa\Buddy\utils\bootstrap.py", line 339, in bootstrap
install_pip_packages()
File "C:\prusa\Buddy\utils\bootstrap.py", line 325, in install_pip_packages
pip_install('-r', str(requirements_path))
File "C:\prusa\Buddy\utils\bootstrap.py", line 303, in pip_install
for line in iter(process.stdout.readline, ''):
File "<frozen codecs>", line 325, in decode
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 1272: invalid continuation byte
C:\prusa\Buddy>
Can anyone advise where I'm making a mistake?
Napsal : 05/02/2025 9:59 am
