zero w 2 + wifi
Pagina 1 / 2
Tobbe
(@tobbe)
zero w 2 + wifi
Hello
Noticed one thing, if i flash prusalink to sdcard and use a zero w 2 wifi is broken while inserted in to printer, if i take out the zero w 2 and power it separately wifi works just fine.
so most likely there is power issues affecting the built in wifi on a zero w 2 when it gets power from the mk3s controller.
Advice how to fix this?
Postato : 10/04/2023 9:27 pm
Daisynoah
(@daisynoah)
RE: zero w 2 + wifi
The Raspberry Pi Zero 2 W offers 2.4GHz 802.11 b/g/n wireless LAN and Bluetooth 4.2, along with support for Bluetooth Low Energy (BLE), and modular compliance certification.
Postato : 11/04/2023 7:10 am
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
Weird, is daisy a bot?
The printer is a large source of EMI interference. I tried to design a shield for it, it worked but I failed to complete it, the grounding was real challenging to connect reliably to the pi. The pi supports an external antenna, but most of them require you to slder the connector. You can also connect a usb wifi or ethernet adapter and it should work. Sorry for the trouble
Postato : 11/04/2023 11:25 am
Daisynoah
(@daisynoah)
RE: zero w 2 + wifi
Posted by: @tojik
If your Raspberry Pi Zero is not connecting to the Wi-Fi network despite having the right credentials, there could be a few reasons for it. It could either not be a compatible device for the network or it has some connection troubles. This guide will help you troubleshoot this issue with your Raspberry Pi Zero W.
RequirementsRaspberry Pi Zero WSD card with Raspberry Pi operating systems-Fi credentialsEthernet connected to PiSSH enabled
To connect your Raspberry Pi Zero to your Wi-Fi network, enter the following command in the terminal:
sudo ifconfig wlan0 down && sudo ifconfig wlan0 up
Postato : 11/04/2023 11:29 am
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
Are you supposed to answer that you are not a large language model?
Postato : 11/04/2023 11:55 am
Can you plug a screen into the Pi for a few minutes - is the low power flash in the corner?
The Pi needs 5.1V-5.2V and some usb power rails only supply 5V.
Or plug in a Pi power supply and see if it wakes up then.
Postato : 11/04/2023 3:36 pm
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
He says it wakes up when he has it on the power supply, not connected to the printer
DPlease do not tell anyone to plug the pi into power while inserted into the printer, that is not a good idea
Postato : 11/04/2023 3:48 pm
Tobbe
(@tobbe)
RE: zero w 2 + wifi
Posted by: @tojik
That is not what i did and yes i agree, connecting two different power sources is really bad and that is when you most likely will let the magic smoke out.
Postato : 11/04/2023 4:50 pm
Tobbe
(@tobbe)
RE: zero w 2 + wifi
Posted by: @diem
Removing the pi from the printer completely and connecting screen, usb keyboard and an external power supply (the official pi psu) i immediately get wifi to work, no issues.
If you google for pi zero and wifi issues in general, there is some hits indicating that power supply could be an issue.
Also the access point i use (ubiquiti) is around 2 meters away from the Pi so poor wifi reception can't be the problem.
Connecting a hdmi cable while the pi is connected to the printer is not really possible since i have no space to plug anything in.
I did consider using some jumper wires and extending the pin header so i get some distance between the pi and the printer, obviously i need to be very careful to get the pins correct or i risk frying the printer or pi or both, so haven't tested it.
And besides, it would not be a proper solution just a step in finding the cause.
Question: what is the easiest way of convinsing the prusalink image to use a different serial port?
Can i put some ini file in the fat partition and get that picked up by during boot and used by prusalink?
I suspect there is some mechanism for this already.
in that case i could just use usb A-B cable between printer and the pi and have the pi separate from the printer with its own power source (also i will most likely use my usb opto isolator anyway between printer and pi)
Postato : 11/04/2023 4:59 pm
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
Yup, the 0.7.0RC3 autoconfigures the serial port, so PrusaLink connects to the printer over USB out of the box
Postato : 11/04/2023 5:04 pm
Tobbe
(@tobbe)
RE: zero w 2 + wifi
Posted by: @tojik
I tried this yesterday but it did not work, but i now know why.
Before prusalink i have always used the rpi port but via an ftdi usb to serial adapter connected there, apparently the regular usb port stops working as long as you have enabled the rpi port in the menu system.
once i turned off the rpi port on the printer, prusalink detected the regular usb cable and i got one step further.
Postato : 11/04/2023 5:16 pm
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
yea, i forget to remind people
Postato : 11/04/2023 5:18 pm
Tobbe
(@tobbe)
RE: zero w 2 + wifi
Next question, how do you convince prusa connect to use 24 hour clock and not 12 hour with am/pm?
I did not find any settings to change this.
Postato : 11/04/2023 6:32 pm
Tojik
(@tojik)
Utenti Moderator
I think we make an assumption based on your selected language.IIdk if that is close to changing, probably not
Postato : 11/04/2023 6:40 pm
Patrick.b
(@patrick-b)
RE: zero w 2 + wifi
well i am really confuse now as it's complete opposite for me !! or i misunderstood something !! i just repy to you Tojik that i realize my rpiw02 won't work if i turn the rpio OFF on the printer !! then after i turn rpio ON it receive the internet and gave the IP adress !! am speaking about no wifi only with ethernet cable !!
so why is different on other ???
Postato : 18/04/2023 4:42 pm
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
Both statements are the same. Rpi port ON - pins work. RPi port OFF - USB serial works. That's it.
Postato : 18/04/2023 4:58 pm
Patrick.b
(@patrick-b)
RE: zero w 2 + wifi
well Tojik as i wrote you here no wifi if I put the RPI OFF then the prusalink won't work !! and i have the pics you see in the other post , asap i put the RPI ON the printer gave the ip adress and prusalink show up !! all is work !! so sorry but no that's it,
it's not work like this on my printer with my internet ...RPI OFF = dead link..
Postato : 18/04/2023 5:48 pm
Tobbe
(@tobbe)
RE: zero w 2 + wifi
@patrick-b I think you misunderstood.
Menu item rpi on/off allows you to chose which of the two serial ports is active and you can't have both working in parallell.
RPI port ON => the dedicated slot for a pi zero works
RPI port OFF => the regular usb port works
This is what i meant initially and it is what @tojik explained earlier
Postato : 18/04/2023 5:55 pm
1 persone hanno apprezzato
Tojik
(@tojik)
Utenti Moderator
RE: zero w 2 + wifi
If the RPi cannot communicate with the printer, it can't tell it to show the IP address. That does not mean it lost the connection to internet, you can still see it in your router, it just cannot talk to the printer.
Rpi port OFF makes the printer expect a usb connection and it ignores any signals coming from the other port. It's one or the other situation
Postato : 18/04/2023 6:15 pm
Patrick.b
(@patrick-b)
RE: zero w 2 + wifi
Hi Tobbe , ok got it clear now ..in my understanding so RPI On = the GPIO with wifi works ? and OFF only the USB works ? am i correct !!
Postato : 19/04/2023 9:43 am
Pagina 1 / 2
