What's the cheapest and easy camera for Mini on Prusa Connect?
ruizit0
(@ruizit0)
Out of the loop for some time on printing hobby, returning back and wanted to setup a camera on Prusa Connect for Mini+
I have a Pi Camera V2 but from my understanding it's not supported, in that case what's the cheapest and easy to setup camera setup people using or recommending at the moment ?
Thank you
Best Answer by _KaszpiR_:
https://jerzeek.github.io/PrintCam-Firmware/ this shows how to do it so that esp32cam sends photos directly to the PrusaConnect.
At the very bottom there is a link to the other sites where that guy sells already assembled and flashed devices, so they are as close to plug and play as possible.
Opublikowany : 07/03/2024 5:51 am
_KaszpiR_
(@_kaszpir_)
I assume you already have a Raspberry Pi if you have Raspberry Pi Camera V2, so the easiest way to do it is just to use my shell script in a loop to send images to PrusaConnect.
See https://forum.prusa3d.com/forum/postid/702311/
In this case this is a CSI camera.
Opublikowany : 07/03/2024 7:40 am
JP Guitars
(@jp-guitars)
RE: What's the cheapest and easy camera for Mini on Prusa Connect?
ESP32CAM,  cost about 6 pounds/euros/dollars https://www.ebay.co.uk/itm/254810284860
This is my design for a mk4 mount which you can adapt to the mini as I've included a Fusion file, includes links to required software: https://www.printables.com/model/668369-esp32-cam-case-and-mount-for-mk4
Opublikowany : 07/03/2024 8:02 am
ruizit0
(@ruizit0)
The idea would be to go away from the Pi and repurpose it for another thing, plan was to use a "standalone" camera.
Opublikowany : 07/03/2024 1:09 pm
JP Guitars
(@jp-guitars)
Have a look at the ESP32Cam then, dirt cheap and gives all you need for remotely keeping an eye on a print.
Opublikowany : 07/03/2024 3:27 pm
_KaszpiR_
(@_kaszpir_)
Opublikowany : 07/03/2024 3:44 pm
1 ludzie polubili
ruizit0
(@ruizit0)
Ok this is exactly what I'm looking for, very nice project to follow.
Thank you for the help
Opublikowany : 07/03/2024 3:49 pm
moell
(@moell)
what if we just want to use a LAN and not go out on the internet (watch from another room in the house)?
Thanks in advance for your response.
Opublikowany : 18/03/2024 11:35 am
_KaszpiR_
(@_kaszpir_)
Esp32 cameras work by default in local networks only, they expose basic web services available locally for video stream and camera snapshot.
You can expose it to internet services but that's another story.
Opublikowany : 18/03/2024 6:22 pm
moell
(@moell)
Thanks KaszpiR,
Do you guys have a procedure for installing one on the MK?  I am not electronically skilled.  Type of ESP32 and connection point information would be appreciated.  Maybe there are instructions somewhere in this forum?
Opublikowany : 18/03/2024 8:31 pm
try this Link
https://lastminuteengineers.com/getting-started-with-esp32-cam/
I bought
https://www.ebay.co.uk/itm/155761260422?var=456239550520
And after programming with Arduino IDE, it works for me.
Opublikowany : 18/03/2024 8:45 pm
_KaszpiR_
(@_kaszpir_)
I'll just want to point out some things here:
- esp32 device + camera - there are various producers of both devices, mostly they work with each other and the software installed on esp32 device
- you can install different types of firmware (software on the device) that runs on that device - such as dedicated esp32 camera via Arduiono or ESPHome projects.
Initial install of the device usually requires physical access to the device via USB (that is you force installation of the firmware on the device) or connecting to its WiFi and then reconfiguring device (you usually just reconfigure the device that was already pre-configured)
Opublikowany : 18/03/2024 9:30 pm
1 ludzie polubili
moell
(@moell)
Thanks KaszpiR.  I enjoy studying and learning new things.  This will be quite interesting.
Aubrey
Opublikowany : 18/03/2024 9:41 pm
_KaszpiR_
(@_kaszpir_)
One more thing - ESP cameras need no connection to your printer - they are totally standalone WiFi devices, you can point it on anything (like a wall to see paint dry).
Opublikowany : 18/03/2024 9:48 pm
1 ludzie polubili
