Upload Printer Firmware (*.bbf) with Prusa Connect
PointNemo
(@pointnemo)
To avoid handling with USB sticks, I propose a feature to upload new firmware versions (.bbf files) like .gcode files with Prusa Connect. If you have more then one printer you will save a lot of time.
This topic was modified 2 years ago by PointNemo
Posted : 13/11/2023 10:18 pm
Tojik
(@tojik)
Member Moderator
RE: Upload Printer Firmware (*.bbf) with Prusa Connect
Hi, firmware updates through connect should already work (apart from the current firmware bug preventing that from actually working)
You might be able to find it under settings next to the firmware version. It is a little hidden for my taste tho
Posted : 14/11/2023 10:00 am
PointNemo
(@pointnemo)
Thanks for this hint. Great.
Posted : 17/11/2023 3:09 pm
PointNemo
(@pointnemo)
Since this week Prusa Connect get the desired function to drop .bbf files and flash the printer.
Thanks to the Prusa team.
Posted : 25/11/2023 11:52 am
Patrick.b
(@patrick-b)
yes i did and saw it but it's not working on each mk4 !! also on 3.9 ? or only MK4 ? it's nice you can choose your fmw on a list and update directly but not each printer!
Posted : 25/11/2023 3:54 pm
