Select Objects to Print when in the queue
Mark Forster
(@mark-forster)
I have a build plate with multiple objects and have had to cancel one of them when previously printing,
It would be good if when queuing I could select which objects to print
At present it is only possible to do this once the print has started.
Even better would be the ability to cancel all then just select which objects to print.
Opublikowany : 23/04/2024 3:46 pm
Why not just re-slice the plate?
Opublikowany : 23/04/2024 4:50 pm
Mark Forster
(@mark-forster)
I can do that but clicking reprint and selecting the required objects would be easier,
Modifying the plate and reslicing would mean a new file uploaded and 'clutter'
The issue is that at the moment I have a print running so I have to remember to cancel objects in several hours time rather than getting it all prepared there and then,
Appreciate the suggestion!
This post was modified 2 years temu by Mark Forster
Opublikowany : 23/04/2024 5:03 pm
Tojik
(@tojik)
Member Moderator
RE: Select Objects to Print when in the queue
Hi, thanks you, that's an interesting idea, will repost to salck. Unfortunately it's one of the nice to have features, gets overshadowed by the features "that should have been there a month ago"
Opublikowany : 24/04/2024 9:13 am
Mark Forster
(@mark-forster)
I totally understand its not a high priority as it can be handled in other ways but I appreciate  your consideration, keep up the good work!
Opublikowany : 24/04/2024 9:38 am
