					                		Raspberry Camera V3 - focus, autofocus, other settings - General discussion &amp; User Experience &amp; Ideas                                    </title>
                <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/</link>
                <lastBuildDate>Tue, 16 Jun 2026 21:11:21 +0000</lastBuildDate>
                        <title>RE: Raspberry Camera V3 - focus, autofocus, other settings</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-786374</link>
                        <pubDate>Thu, 19 Mar 2026 13:42:46 +0000</pubDate>
                        <description><![CDATA[Not sure if this has been updated in a while, but I was having a similar problem getting the pi cam v3 to focus while mounted with an X axis motor mount.  I found that there is now a setting...]]></description>
                        <content:encoded><![CDATA[<p>Not sure if this has been updated in a while, but I was having a similar problem getting the pi cam v3 to focus while mounted with an X axis motor mount.  I found that there is now a setting in prusa_printer_settings.ini for camera focus:</p><p></p><p>id_string = /base/soc/i2c0mux/i2c@1/imx708@1a</p><p>name = RaspberryPi Camera: imx708</p><p>driver = PiCamera</p><p><strong>focus = 0</strong></p><p>resolution = 3840x2400</p><p>trigger_scheme = TEN_SEC</p><p>I've tried changing this value to 1 or 2, but it doesn't seem to have any effect.  If set to 2, after a reboot it defaults back to zero, so I'm assuming 2 is not a valid parameter.  Set to either 0 or 1 it still wants to focus behind the printer or at closest the Z axis rod.  The nozzle is still blurry 20cm away even though the camera should be able to focus on anything further than 5cm away.</p><p><br />PrusaLink 0.8.1  running on Raspberry Pi Zero 2 W with an i3 MK3S+</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Inspector5</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-786374</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-773483</link>
                        <pubDate>Tue, 09 Dec 2025 19:12:53 +0000</pubDate>
                        <description><![CDATA[Same here , is there any news for this?]]></description>
                        <content:encoded><![CDATA[<p>Same here , is there any news for this?</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Ger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-773483</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-768352</link>
                        <pubDate>Thu, 30 Oct 2025 12:19:54 +0000</pubDate>
                        <description><![CDATA[Hey everyone,
I’m still running into issues with blurry images when using the RPi Camera V3 Wide connected to an RPi Zero 2W on my Prusa MK3S+.
I’m currently running PrusaLink 0.8.1, and w...]]></description>
                        <content:encoded><![CDATA[<p class="p1">Hey everyone,</p>
<p class="p1">I’m still running into issues with blurry images when using the RPi Camera V3 Wide connected to an RPi Zero 2W on my Prusa MK3S+.</p>
<p class="p1">I’m currently running PrusaLink 0.8.1, and while reviewing the release notes for 0.7.1-rc1, I noticed the mention of the prusa_printer_settings.ini file. Inspecting it, I found that the focus slider in the PrusaLink web interface updates the focusvalue between 0 and 1.</p>
<p class="p1">According to the official Raspberry Pi documentation (<a href="https://datasheets.raspberrypi.com/camera/camera-module-3-product-brief.pdf">https://datasheets.raspberrypi.com/camera/camera-module-3-product-brief.pdf</a>), the focus range of the V3 Wide starts at 5 cm. I’m using this mount (<a href="https://www.printables.com/model/1253492-prusa-mk3s-mk3s-pi-camera-v3-mount">https://www.printables.com/model/1253492-prusa-mk3s-mk3s-pi-camera-v3-mount</a>), which positions the nozzle roughly 5 cm from the camera when the X-axis is set to 10.</p>
<p class="p1">At this distance or greater I can’t get a sharp image — changing the focus slider doesn’t seem to affect the image at all, even though the value in prusa_printer_settings.ini does change. However, the image remains out of focus in both cases and values in between as well. I will attach two images with both of the extremes focus values for inspection. To me, they look identical. I tried restarting PrusaLink in between setting changes as well. </p>
<p>Am I missing something to enable or use manual focus on this setup? Is there any way to activate autofocus instead?</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/10/cb2227ca-focus-0-scaled.jpeg"><img class="size-medium wp-image-181325" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/10/cb2227ca-focus-0-600x500.jpeg" alt="" width="600" height="500" /></a> Focus 0 <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/10/255e1c82-focus-1-scaled.jpeg"><img class="size-medium wp-image-181326" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/10/255e1c82-focus-1-600x500.jpeg" alt="" width="600" height="500" /></a> Focus 1</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Valentin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-768352</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-757832</link>
                        <pubDate>Thu, 17 Jul 2025 11:59:47 +0000</pubDate>
                        <description><![CDATA[Can we please get this address in the next release? Could you maybe turn off the auto focus and make sure the manual focus slide bar works for the Pi Camera v3. Thanks!]]></description>
                        <content:encoded><![CDATA[<p>Can we please get this address in the next release? Could you maybe turn off the auto focus and make sure the manual focus slide bar works for the Pi Camera v3. Thanks!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>MontesDesigns.biz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-757832</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-730934</link>
                        <pubDate>Sat, 28 Dec 2024 12:32:40 +0000</pubDate>
                        <description><![CDATA[I have the Wide version of the RPi Camera, and yeah its pretty blurry for some reason]]></description>
                        <content:encoded><![CDATA[<p>I have the Wide version of the RPi Camera, and yeah its pretty blurry for some reason</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Velocity</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-730934</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647698</link>
                        <pubDate>Fri, 24 Mar 2023 10:22:41 +0000</pubDate>
                        <description><![CDATA[Yea, the PiCamV3 came out as I was finishing the support. I tried it out, it showed an image, i slapped it in the supported list and that was that, assumed it autofocussed by default. Welp, ...]]></description>
                        <content:encoded><![CDATA[<p>Yea, the PiCamV3 came out as I was finishing the support. I tried it out, it showed an image, i slapped it in the supported list and that was that, assumed it autofocussed by default. Welp, turns out it does like once, then stays that way. Been trying all yesterday to make it focus but so far no dice. Will try to fix it for the next release. Also wide variants of picamv3 are not in the whitelist in the RC3, so those won't work till the next release too.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Tojik</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647698</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647675</link>
                        <pubDate>Fri, 24 Mar 2023 00:14:45 +0000</pubDate>
                        <description><![CDATA[The focusing distance for V3 is just 10cm and I placed the camera further away, so it should focus just fine. It does focus on things on the other side of the room when I turn it around, but...]]></description>
                        <content:encoded><![CDATA[<p>The focusing distance for V3 is just 10cm and I placed the camera further away, so it should focus just fine. It does focus on things on the other side of the room when I turn it around, but I don't see it self adjusting the focus when I put random things in its view. As if autofocus wasn't enabled.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Shushuda</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647675</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647376</link>
                        <pubDate>Thu, 23 Mar 2023 15:51:25 +0000</pubDate>
                        <description><![CDATA[IIrc the camera is available with a range of lenses, check you are not closer than the shortest focussing distance for your lense - and turn it around to see if it can focus on something fur...]]></description>
                        <content:encoded><![CDATA[<p>IIrc the camera is available with a range of lenses, check you are not closer than the shortest focussing distance for your lense - and turn it around to see if it can focus on something further away.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/">General discussion &amp; User Experience &amp; Ideas</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-647376</guid>
                        <title>Raspberry Camera V3 - focus, autofocus, other settings</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-646996</link>
                        <pubDate>Thu, 23 Mar 2023 03:10:47 +0000</pubDate>
                        <description><![CDATA[I&#039;ve recently attached a Raspberry Camera V3 to my PrusaLink-running Zero 2 W. It&#039;s detected by the newest PrusaLink just fine, but the image is very blurry. V3 has autofocus, but it looks l...]]></description>
                        <content:encoded><![CDATA[<p>I've recently attached a Raspberry Camera V3 to my PrusaLink-running Zero 2 W. It's detected by the newest PrusaLink just fine, but the image is very blurry. V3 has autofocus, but it looks like it's not working in PrusaLink.</p><p>I've been wondering if camera settings/control is handled by PrusaLink or if it can be setup manually somewhere directly on the Pi and PrusaLink will use those settings. I've never used a camera with Raspberry before, so I'm not sure how to approach this.</p><p>Can focus / autofocus be set somehow via ssh? I just want to reduce the blur in those snapshots.</p><p>I know that Octoprint has plugins for camera control and they allow to set autofocus on/off, set manual focus value, exposure and other things. Are there any plans to add a way to set those settings (at least focus and autofocus) directly in PrusaLink and/or Connect?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/raspberry-camera-v3-focus-autofocus-other-settings/#post-646996</guid>
