PrusaLink Case
sp3cialk
(@sp3cialk)
Mitglied
PrusaLink Case
I saw some early beta testers (when things were still being discussed on slack) had some new case for the rpi that looked really slick.  I'm sure it was shared in slack.  Wondering if that could be made available here for us new testers?  I've added some photos of the case I'm talking about
Veröffentlicht : 23/08/2021 7:48 pm
printing overnight
(@printing-overnight)
Mitglied
I'm not sure if this is really useful right now. As far as I know, right now we can only test PrusaLink via the internal pin header connection, while the case on your pics would probably need some kind of external cable for connecting to the MK3S?
Veröffentlicht : 23/08/2021 8:04 pm
Tojik
(@tojik)
Mitglied Moderator
I'm not suggesting anything but
File /etc/Prusa-Link/prusa-link.ini
[printer]
port=/dev/ttyACM0
baudrate=115200
Put whatever port you like there, as long as there is some sort of an MK3 on the other side, it should work, USB and everything.
Have a good one 😉
Veröffentlicht : 24/08/2021 12:11 pm
6 weiteren Personen gefällt das
Eric E
(@eric-e)
Mitglied
.ini file is where?
I just downloaded .5.2 (or whatever is current at the moment), and there is not a prusa-link.ini file anywhere on the file system.
There certainly is not an /etc/Prusa-Link
There is Prusa stuff in /home/pi, and I didn't put it there myself, so the download is correct.
Clues?
Don’t trust forum advice.
Veröffentlicht : 15/09/2021 1:20 am
Eric E
(@eric-e)
Mitglied
Okay, I am a knucklehead
Created that file, and it boots up.  Raspberry Pi 4, USB.
Currently printing.  Nice.
Veröffentlicht : 15/09/2021 12:57 pm
Tojik
(@tojik)
Mitglied Moderator
Sorry yea
Could have told you that, sorry. The last config system i employed did create files and folders, this one does not, but has other benefits. Soo yea, hopefully someday it will
Veröffentlicht : 15/09/2021 2:08 pm
Caveman
(@caveman-2)
Mitglied
me can't find folder
How to add folder and file? before or after boot?
Veröffentlicht : 16/09/2021 7:30 am
Tojik
(@tojik)
Mitglied Moderator
Just add it
Whenever you feel like it, just restart prusa-link or the whole raspi afterwards for the changes to have a chance to load
Veröffentlicht : 16/09/2021 7:53 am
printing overnight
Mitglied
RE: PrusaLink Case
Did you ever succeed finding an .stl for that case?
Posted by: @sp3cialk
I saw some early beta testers (when things were still being discussed on slack) had some new case for the rpi that looked really slick.  I'm sure it was shared in slack.  Wondering if that could be made available here for us new testers? ...
Veröffentlicht : 19/11/2021 9:42 pm
Nikomi
(@nikomi)
Mitglied
I made one...
Diese r Beitrag wurde geändert Vor 4 years von Nikomi
Veröffentlicht : 24/11/2021 12:40 pm
madpro
(@madpro)
Mitglied
RE: PrusaLink Case
Added the new file/parms. Working on Pi3B too. Printer connected via USB.
Veröffentlicht : 30/11/2021 8:10 pm
madpro
(@madpro)
Mitglied
RE: PrusaLink Case
Note: normal reboot via SSH does not work after adding the file presently (Pi3/4). use (sudo reboot --force --force) for beta.
Veröffentlicht : 07/12/2021 4:35 pm
Dmitri K
(@dmitri-k)
Mitglied
RE: PrusaLink Case
So to confirm hack above sort of allows you to use a pi 4 via USB? My issue is that current case I have on my mk3s doesn't allow a zero on back and also the pins that came with it are a bit short, I can connect via wires to same pins, but a usb version would work best.
Veröffentlicht : 23/12/2021 7:52 pm
Eric E
(@eric-e)
Mitglied
RE: PrusaLink Case
https://forum.prusa3d.com/forum/bugs-errors/0-5-2-documentation-missing-for-usb-and-non-zero-pi
It is not "sort of", it works just fine via USB.  Been using a Pi4 since my day one on this.
Veröffentlicht : 23/12/2021 10:14 pm
Timo
 Timo
(@timo-2)
Mitglied
Looks great.
Maybe the dev team could add it to Prusa Link -> gcodes examples?
I have no special talent. I am only passionately curious
Veröffentlicht : 24/12/2021 5:54 pm
