Prusa connect issue slow speed
Qubiki 3D
(@qubiki-3d)
Hello. Today it is 12.11.2013.
I have kinda problem taht prusa connect is not usable because of how it is working. I mean the page is verry verry slow. And when I uploaded file to to my printer it is sending it with speed 800bit/s - 2kb/s So it is not usable and i must to play with usb sticks to print anything. The file to prusa connect was sended in 1-2 seconds. But now even file 2-4mb gcode is transimted to printer in 3-4 hours
Napsal : 12/11/2023 5:53 pm
Tojik
(@tojik)
Member Moderator
RE: Prusa connect issue slow speed
Hi, please try ethernet, we are making a better firmware that should alleviate this problem. It's weird that you get less than a hundredth of the speed we normally get - still slow, but not THIS much. Sorry for the inconvenience :/
Napsal : 13/11/2023 2:41 pm
Qubiki 3D
(@qubiki-3d)
I have both printers connected via ethernet. Sending via prusalink is okay with speeds. But the issue was  with site. The page of prussa connect was loading aprox 5-10 minutes. And the sending from prussa connect site was verry slow end often the page froze for dozen of minutes. Like there was problem with routing from Poland to your prusa connect servers. ATM it is working like it should everything is loading in few seconds. I was checking from 2-3 other ISP and the issue was the same yesterday.
Napsal : 13/11/2023 5:50 pm
1 lidem se líbí
Petr Vacek
(@petr-vacek)
Prusa MK4S, printing a file using Connect. Failes 2 times ("gCode transfer too slow, check connection or USB" - something like so). WiFi connection was ok, printer connected. Pressed "resume", but failed to resume. USB drive was in, but I assume that the printer "knows" the original source of the file. My print is lost.
The printer heats up, then goes to the last printed position to continue, then touches the print and fails to continue with message "Chyba disku nebo souboru, připojte disk znovu". This happened already two times.
Design • Code • Make
Napsal : 27/11/2024 1:42 pm
7footman
(@7footman)
I just got my Mk4s and have been trying to use PrusaConnect to send files and print remotely. I'm having the same issue as petr-vacek with prints failing due to slow gcode transfer.
Additionally, I can't even just send a file to the printer. I get an error saying that the file upload failed. This is not just for Gcode but a firmware update as well.
The only way I can use my Mk4s is via the USB stick. I'd love to have this issue resolved so that I can actually make use of PrusaConnect.
Napsal : 12/12/2024 3:35 am
1 lidem se líbí
federiqo
(@federiqo)
This is still a problem. Does anyone know how to fix it? Happening on a new Core One
Napsal : 05/06/2025 3:35 am
1 lidem se líbí
GwynnePrints
(@gwynneprints)
This is also happening on my factory built core one.
both the core one and the computer are connected by wire to the same modem.
Posted by: @federiqo
Napsal : 19/06/2025 7:39 am
GwynnePrints
(@gwynneprints)
This is also now occurring on my MK4S.
any solution from Prusa for this 2+ year old problem?
Napsal : 08/08/2025 2:51 am
3Delight
(@3delight)
Moderátor Moderator
Have you taken a look at this: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.6-alpha  ?
Napsal : 08/08/2025 1:43 pm
1 lidem se líbí
GwynnePrints
(@gwynneprints)
Unfortunately it still occurs on the latest Alpha build, both on wired or wireless.
Oddly, I will have greater success of the file fully transferring correctly (once Connect service is live) by transferring the file to the printer and then starting the print from its screen.
Napsal : 08/08/2025 1:46 pm
