Feature request: Filament management in PrusaConnect
Schmedi
(@schmedi)
Hi everyone, I'm new to the forum and have been trying out PrusaConnect for a few weeks now. I noticed something that I think would be great to implement.
I would find it very nice if there was some kind of filament management in Prusa Connect.
My idea:
You can store about 5 or more filaments with name, color, material and weight in PrusaConnect and every time you change the filament you can select which filament is stored. When you print something, the used material (weight) is automatically deducted from the selected filament, so you can also see how much filament is left on a roll.
I hope you understand what I mean, otherwise I can explain it in more detail.
Posted : 27/05/2024 7:37 pm
4 people liked
When it matters most people find it easier to weigh the spool.
Posted : 28/05/2024 3:48 am
RE: Feature request: Filament management in PrusaConnect
I agree, I find it easier to trust what the scale is showing me than what's on the screen, as it would be easy to forget to select the correct filament.
Posted : 28/05/2024 10:47 am
Alex E
(@alex-e)
Octoprint has a similar feature , "Spool Manager" as i can`t put out and weight always 5 spools with the MMU , so i am thinking of changing back to Octoprint from PrusaConnect , as it doesn`t have this feature
Posted : 31/05/2024 10:35 am
RalfD
(@ralfd-2)
I also would like to have this implemented in Prusa connect! At the moment I use Spoolman together with Octoprint. This works perfect! If I get the CoreOne I would like to change to Prusa Connect, but without a proper spool management I am hesitating with the switch to Prusa connect.
Posted : 14/03/2025 7:28 am
RalfD
(@ralfd-2)
I Think something is in preparation.
in Connect there is a little g after PLA at the filament selection.
Maybe its a hint, that there will follow a management of the used filament weight.....
let's hope that there will be an announcement...
Posted : 07/07/2025 3:02 pm
Bouta
(@bouta)
I think filament management should be a serious part of PrusaConnect. We have many team members working with one printer. I think there should always be an option to attach a specific filament profile to extruders and then every time a member opens the Slicer and is connected with PrusaConnect - he would see an option "Piotr connected filament XYZ to extruder 2 on PrusaXL"... We would then avoid going over to the printer to make sure what is installed, finding the printer profile etc.... Also, I think there should be a library of filament profiles that is shared with all team members - to complement the previous option.
Posted : 01/10/2025 5:40 am
