Cant add or edit Folders???
As you can see below in the images I posted, users are able to see projects on the micro and regular SD cards on the machine with all their files.
But how are we supposed to place projects into folders, name those folders, delete those folders, etc...
This is very important to me for the sake of organization.
Folder name examples:
Test prints
Printer Parts & Upgrades
Cart Parts
House Items
RE: Cant add or edit Folders???
Currently only via SSH. But I think this is a planned feature.
- firmware 3.10.1-4697 PrusaLink - Raspberry Pi Zero, version 0.6.0
If you publish via PrusaSlicer, you can provide a complete path. It creates the folder structure then
Interesting. I’ll look into that further. Still would be like to do it through Prusa connect though. Incase things change and you want to rename or re organize.
that's true ... I also would love to see that.
Currently I do it using ssh ... You can move your files around over there, create some folders and put them in the right ones. They also and up in those folders in the web UI.
My most requested feature for sure. For now I have been using the Prusa Slicer work-around detailed above.
