Why heating bed when changing filament?
mrstoned
(@mrstoned)
I wonder if there is a reason why the printer also heat the bed when manually changing the filament (not via color-change in gcode).
I usually preheat the nozzle to the printing-temp of current filament, then go to filament-menu and unload. It then starts to heat the bed (not needed).
I then use the load filament from menu, and again it pre-heats bed to temp as well (or starts to) but will change the filament if nozzle is up to temp.
Not critical, just annoying.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Veröffentlicht : 12/08/2021 9:31 am
Mitglied
heating
Every printer I own does that.  I would guess that they assume you are planning to print if you are changing filaments.
Veröffentlicht : 12/08/2021 9:51 am
mrstoned
(@mrstoned)
Possibly
I guess that's true.
For my old delta and nereus i have always changes the filament manually by heating the nozzle, then push a tiny bit out (the ramming on the mini) and yank it back.
Granted, when using the change filament on my first printer, it was excrutiatingly slow feeds so i just always used the manual process after that.
Veröffentlicht : 12/08/2021 11:19 am
