Where are the firmware updates?
Page 2 / 3
Rat_Patrol
(@rat_patrol)
RE: Where are the firmware updates?
I did put 4.0.2 in my Mini, but as expected, no help to my issues.
Posted : 04/02/2020 5:54 pm
towlerg
(@towlerg)
@texy
The very point I was trying to tease out without using a blunt instrument.
Having said that, lets use that blunt instrument anyway, if anyone can get acceptable results (several good looking examples posted) using firmware vers X, if you use that same firmware and cannot repeat those results, your problem is hardware.
Posted : 05/02/2020 1:45 pm
Rat_Patrol
(@rat_patrol)
Well, my particular Mini is headed back to Prusa to figure out why it won't work right.
Posted : 07/02/2020 3:59 pm
Rob
 Rob
(@rob-13)
My mini arrived and I see 4.0.2-FINAL is on the included USB stick
Posted : 07/02/2020 9:10 pm
Olef
 Olef
(@olef)
Posted by: @visuar
Interesting. So people are now receiving printers with unreleased firmware.
Posted : 08/02/2020 8:55 am
Benji
(@benji)
@olef
4.0.2 has been available to download for days now. Only change is support for the new rotary encoder.
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Posted : 08/02/2020 9:00 am
Olef
 Olef
(@olef)
@asdf-tgz
Thanks, I am aware 4.02 has been there for some days. And yet Github clearly shows only one actual release and that is 4.01. That is all I was referring to.
Posted : 08/02/2020 9:15 am
towlerg
(@towlerg)
4.0.2 is on the drivers page https://www.prusa3d.com/drivers/
Posted : 08/02/2020 1:08 pm
Olef
 Olef
(@olef)
@towlerg
Looking at all the changes noted into 4.0.2 on Github, versus the 4.0.2 on the download page which apparently only has the change for the different encoder, I believe there has been a mistake in naming. Based on the changes listed I believe the drivers page version should be more like 4.0.1a.
It is now 52 days since the last Mini firmware, excluding the hardware change version above... 🙁
Posted : 09/02/2020 12:43 pm
Oxygen
(@oxygen)
Movement @ github
https://github.com/prusa3d/Prusa-Firmware-Buddy/pull/210
and
https://github.com/prusa3d/Prusa-Firmware-Buddy/pull/208
and this was all a prelude to
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v4.0.3
Stock MK4S with FW 6.2.6
Posted : 12/02/2020 4:03 pm
Crawlerin
(@crawlerin)
Omg omg omg there's 4.0.3 RC1 with tons of letters to read in changelog 😊
Posted : 12/02/2020 6:34 pm
With_Maltodextrin
(@with_maltodextrin)
Classic Jerk fix
During the merge of the latest Marlin code to our firmware, the “Junction Deviation” was enabled instead of “Classic Jerk”. This release fixes it by switching back to the “Classic Jerk”.
(From the v4.0.3 release notes)
Someone definitely needs to compare their Mini's movements before and after 4.03 when it's released to see if that's a noticeable difference... (I don't get mine til May or would do that myself)
Posted : 12/02/2020 6:39 pm
jweaver
(@jweaver)
Posted by: @crawlerin
But no network features... dissapointing.
Posted : 12/02/2020 6:45 pm
Olef
 Olef
(@olef)
On the 4.0.1 firmware the LAN port was enabled and it picked up an IP by DHCP. I could browse it and see an under construction page with the temperatures listed.
Just loaded the new 4.0.3-RC1 and the LAN port now appears disabled. It is now greyed out on the display. The new firmware does have a LAN info page though, which reports IP details etc.
Good to see an update at last even if it is mainly bug fixes.
Posted : 12/02/2020 11:14 pm
Rat_Patrol
(@rat_patrol)
Yup, get the bug fixes done, then work on the web interface.
Posted : 12/02/2020 11:15 pm
LittleNeutrino
(@littleneutrino)
@olef
Yeah I noticed the LAN port too, technically its not disabled, its still pulling an IP Address, the device isnt listing it, and you cannot access the web interface though sadly. Im hoping they at least put basic functionality on there pretty quick.
Posted : 12/02/2020 11:46 pm
Crawlerin
(@crawlerin)
There was a bug reported, when firmware crashed after some time idling and connected to the network. It is possible it was disabled for that simple reason they don't want to deal with such issues.
Posted : 13/02/2020 12:00 am
Area51
(@area51)
Very nice we finally got a firmware update for the Mini! Can't wait to test it...
Posted : 13/02/2020 5:00 am
Rat_Patrol
(@rat_patrol)
I put 4.0.3 into my troubled Mini.
Changed some things, but my first layer troubles are still there just the same.
Posted : 13/02/2020 7:53 pm
Area51
(@area51)
Posted by: @rat_patrol
Haven't tried the RC1 yet, but hoped that bed level was fixed...
Posted : 13/02/2020 8:25 pm
Page 2 / 3
