Unofficial Prusa Mini Wait Thread
Strona 46 / 241
Skewed Perception
(@skewed-perception)
RE: Unofficial Prusa Mini Wait Thread
It's available as a replacement part in the shop. You can just order it later and install it.
https://shop.prusa3d.com/en/mini/1016-filament-sensor-mini-assembly.html
Opublikowany : 26/12/2019 7:58 pm
Krope
(@krope)
get that Message "Sorry, only registered i3 printer owners can access this product. If you bought the i3 3D printer from our e-shop, please, contact us via live chat."
did you think its a Problem when i ask in the Prusa Shop they add the Sensor to my Package?
Opublikowany : 26/12/2019 9:09 pm
Have a word with chat!
they will sort you out!
Regards, Joan
Opublikowany : 26/12/2019 9:19 pm
Krope
(@krope)
sort me 0ut ..... sounds like may i wait longer? did someone know when the chat is available?
This post was modified 6 years temu by Krope
Opublikowany : 26/12/2019 9:57 pm
Hi Kropexx,
I suspect there has been a holiday in Prague, so normal service is likely to resume later today, 27th December 2019.
Opublikowany : 27/12/2019 12:38 am
adynis
(@adynis)
About 5 hours ago the chat was available, I just had an answer on a question.
Opublikowany : 27/12/2019 12:50 am
Krope
(@krope)
Wow... i just trie it out to Start a Chat and they are anwser me at that Time 😀
It is all done , i payed the 20USD on Paypal and they change my order an put the Filamament sensor in.
Great Service....
Opublikowany : 27/12/2019 12:57 am
@joantabb
I hope you are right.
Opublikowany : 27/12/2019 1:09 am
Sfbrain
(@sfbrain)
Woop, Woop, Woop !!
Just got an email to say DPD will deliver my Mini today (ordered 13th Oct, shipped 20th Dec)
Have to say this forum has been fantastic, especially recently when others have been having various issues with their new Mini's
I certainly plan to do the following before turning mine on for the first time ...
1.  Check the tie wraps holding cables on X carridge (strain at extreme movements)
2.  Check Minda hight
3.  Check hot end grub screws are tight
4.  drop a little WD40 down the control knob shaft on the LCD unit
Any other suggestions guys ?
Thanks
S
Opublikowany : 27/12/2019 8:51 am
Koen Kooi
(@koen-kooi)
Posted by: @steve-4
Woop, Woop, Woop !!
Thanks
S
WD40 doesn't play nice with a number of plastics, so think twice before using it in situations were it might spill beyond the metal.
Opublikowany : 27/12/2019 9:43 am
Olef
 Olef
(@olef)
I only tried WD40 because my control was completely seized and unusable. Even then I took care to mask off everything except the control shaft to prevent overspill of the lubricant. I would not use it on a new unit.
Opublikowany : 27/12/2019 10:59 am
Sfbrain
(@sfbrain)
Posted by: @olef
Fair play guys, wont use WD40, maybe some light oil 😉
S
Opublikowany : 27/12/2019 11:40 am
Sfbrain
(@sfbrain)
Its just arrived 😀
I ordered some filament with it, but its not with the printer, anyone else order filament with their printer and did they arrive seperatly ?
S
Opublikowany : 27/12/2019 11:47 am
SteMar
(@stemar)
I ordered one 🙂 I must wait long time :/ :/
Opublikowany : 27/12/2019 11:50 am
Olef
 Olef
(@olef)
@steve-4
The control should not need lube, I would definitely not use oil
Opublikowany : 27/12/2019 11:57 am
Sfbrain
(@sfbrain)
UPDATE ......
Filament was in the box with the printer, great box design !!
Just as a reference for others, my Mini's build date was 17th Dec
It will be interesting to see if any of the issues others were having are also in mine (I read somewhere that a Mini with issues was built on the 4th Dec)
S
Opublikowany : 27/12/2019 12:05 pm
Andreas Steinel
(@andreas-steinel)
Posted by: @steve-4
Did you refer to the BuddyBoard production date on the test receipt? If not, where do you read your build date?
Opublikowany : 27/12/2019 12:12 pm
Andreas Steinel
(@andreas-steinel)
Posted by: @a-steinel
No obvious transport deformations on the packaging and no obvious defects/breakages on its interior.
I have to correct myself. On actual assembly, I also noticed the broken frame as others did before. I don't mind, it is not a crucial part and the broken side is directly attached to the other parts of the printer (metal of the heatbed frame), so no further breakage is likely.
Opublikowany : 27/12/2019 12:15 pm
Sfbrain
(@sfbrain)
Posted by: @steve-4
Production date on test slip under buddyboard
Thought this might be a suitable reference date, to see if there were any issues addressed as the units were made ?
S
It is good to always save thus slip of paper.
Opublikowany : 27/12/2019 12:53 pm
Strona 46 / 241
