RE: Unofficial Prusa Mini Wait Thread
Finally got a minute to put the files up for v2. https://www.prusaprinters.org/prints/24701-rocinante-v2
It's actually closer to v2.5 but I didn't want to wait for the print to finish before putting it up.
I re-created the base so it would be taller and not hide any of the lettering.
Very nice, but you need a separate thread for this.
Texy
@frankincell
you need to print and attach the PDCs to the Roci 😉
I'm not a mad scientist, I'm an angry engineer in training.
@hawwwran
I see R3 parts submitted to Github https://github.com/prusa3d/Original-Prusa-MINI/releases/tag/R3 I tried to alter the sheet but failed (lack of rights)
Stock MK4S
@oxygen
I can see that there are some marked R3 already.
I have come here to chew bubblegum and perfect my MINI ... and I'm all out of bubblegum.
I did that, but some of the records are locked and cannot be updated (looked like a rights issue)
Stock MK4S
Hope I did it get right - put R2 and R3 parts into a project (there are at the moment only 2 new parts) - I had to ZIP it
Best regards, Clemens
@clemens-m
So... Other than the letters R1 and R3... I'm not good enough to spot the difference... Can anyone see what it is?
All your filament are belong to us!
2nd try - 1 provided download didn´t work:
MINI Comp R2 R3
(now it is working as it should)
On the part "Mini heatbed cable cover ..." they increased the height of the part - they gave more space for cable and contacts and so on I think. On the part "Mini z-carriage they did something on the small parts for increasing strength on specific areas in the part". To find out what I mean select this part in slicer and press button "Seperate in objects" and then move the big part aside. You then will find lots of small parts - but they are now fallen to the printer surface
I cannot find a difference at the second part.
Does somebody know from what material the parts of the Mini are made off? is it ASA or PETG? (I assume that PLA is out of the question)
Stock MK4S
Printed plastic parts is PETG.
OK thanks I think I'll add some Prusament PETG to my Mini Order
Stock MK4S
@clemens-m
On the z-carriage-front, they shifted the positions of some of the infill solids. The lighter pinks are Rev3, darker are Rev2
@tlovern
Just in case anyone wants to work on the guns... I'm attaching my current work-in-progress....
On another note... On version 2, I worked for a long time to put those heat-tiles on ship, and they only appear as an artifact when printed. Even with a 0.25mm nozzle.
So much for attaching my work in progress... it wouldn't let me attach the file...
Ok, here's a link instead... Rocinante-Gun-v0015.3mf
So there are now new Rev 3 parts. Could that cause some delay in production as they print these new parts?
I don´t think so as there are only two new parts. And they can switch at every time from R2 to R3. I had a look at the two parts and decided not to change these parts.
There were five orders marked as shipped in the following community spreadsheet yesterday.
Two from 15th10
Three from 16th10
There was one order from 17th10 directly marked as delivered.
There were two other orders marked as delivered.
https://docs.google.com/spreadsheets/d/1cEUO-8AQevqBbD37C25bSPWbb3Lpk6q_-WZuZ0HOIOY
How many spools with at least 250g left is your stock right now?
My 15th10 order was delivered/received (Canada) last night. Yay!
The future is already here, just unevenly distributed. - W. Gibson.
