Unofficial Prusa Mini Wait Thread
Pagina 114 / 241
Matteo Cristini
(@matteo-cristini)
RE: Unofficial Prusa Mini Wait Thread
There's an official article on the help page regarding the heatbed connection:
Link
I promise, this is the last time I mention the heatbed. Now back to the wait thread 🤩
Postato : 21/02/2020 11:16 am
vbl
 vbl
(@vbl)
Posted by: @matteo-cristini
Link
Thanks for linking. I've read the original reddit post (don't have a FB account, so cannot comment on that) and I've been wondering what the  guy wanted to prove by measuring resistance of the whole bed from both sides of the board. Plus, sticking multimeter probes in bolt heads gives him wildly flucutating readout, as I'd expect when sticking probe to uncleaned surface of a zinc-coated bolt.
One should measure resistance between the copper pad and the wire terminal/cable connector since bed's resistance is irrelevant here. Nicely shown in the linked article.
Postato : 21/02/2020 12:25 pm
Utenti
Or just add it to every page: https://docs.google.com/spreadsheets/d/1cEUO-8AQevqBbD37C25bSPWbb3Lpk6q_-WZuZ0HOIOY/htmlview
Postato : 21/02/2020 1:24 pm
MileHigh3Der
(@milehigh3der)
Got it.   Arrived a day late with no explanation from FedEx.
 Going to play hooky from work this afternoon to play with it. Easy to do when you have a home office. 🙂
Postato : 21/02/2020 5:32 pm
RetroBill
(@retrobill)
Posted by: @milehigh3der
Yup, me too. I am assembling my mini in my home office as we speak. Can wait to get my first print 🙂
Postato : 21/02/2020 5:36 pm
clothbot
(@clothbot)
@hawwwran
Is this an internally-generated spreadsheet? If so, I'm not seeing my order #344755 showing up anywhere near 15-10-2019...
The future is already here, just unevenly distributed. - W. Gibson.
Postato : 21/02/2020 6:51 pm
Crawlerin
(@crawlerin)
@andrew-5
No, community members contribute to it.
Postato : 21/02/2020 6:52 pm
Matteo Cristini
(@matteo-cristini)
@andrew-5
It's not! It's a community document. Everyone puts in his order by himself 😉
Postato : 21/02/2020 6:53 pm
Matteo Cristini
(@matteo-cristini)
@crawlerin
You beat me by one minute. Nice!
clothbot
(@clothbot)
Posted by: @crawlerin
@andrew-5
Phew! Had me worried for a moment there. I'll add my entry this evening after work.  Thanks!
Postato : 21/02/2020 6:56 pm
Tomas T
(@tomas-t)
Got mine today!
Building was easy, really easy. Was expecting it much more complicated.
Struggled with the first layer, I changed it way to little per time. the in built layer test turn out ok-ish to soon. Ended up lowing it to around -0,7.
Now printing a benchy and looking real good but only 30% done, so fingers crossed.
Everything was in the box, feets etc. The only down side was the electronics box had a printing issue over the power plug hole. Looks like there was two layers of the print that did not stick.
But really positive experience so far, easy to pick up and start with.
Postato : 21/02/2020 9:39 pm
RetroBill
(@retrobill)
Ok folks, only took me 30 minutes to assemble the Mini.
I am now ready to do firmware and calibration.
Will let you know how it goes 🙂
Questo post è stato modificato 6 years fa da RetroBill
Postato : 21/02/2020 10:12 pm
Crawlerin
(@crawlerin)
30 minutes? You guys are so fast ... I probably hold record of slowest MINI assembly. Mine took around 6 hours. Partially because of an unexpected New Year's Eve celebration but still.
Postato : 21/02/2020 10:36 pm
2 persone hanno apprezzato
Tomas T
(@tomas-t)
First print was working perfectly but in the end of the chimney it failed. Do anyone have any idea what I can do to change it?
Postato : 21/02/2020 11:29 pm
RetroBill
(@retrobill)
I am having a hard time with first layer live Z.
Can you guys tell me what what your live Z value is so I can at least have a starting point?
Thanks!
Postato : 22/02/2020 1:18 am
Pete Brown
(@pete-brown)
Posted by: @k9bub
Thanks!
Check your X-axis to see if it's close to parallel with the build plate. I had to shim mine to work.
https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/now-i-know-why-ive-had-so-many-problems-this-evening-x-axis-out-of-parallel/#post-194422
My Z setting is -0.902, but I couldn't get this to behave until I fixed that X axis.
Pete
Postato : 22/02/2020 1:22 am
Frankincell
(@frankincell)
@tischan
Make sure your belts are tight and that your fan has good air-flow.
That chimney melting looks like the print head wasn't moving right and / or there was no cooling.
All your filament are belong to us!
Postato : 22/02/2020 1:24 am
Frankincell
(@frankincell)
@k9bub
My Z-offset from First Layer Calibration is was -0.850 when I first received it.  I thought that was crazy, but it appears to be common.
I swapped out my 0.4 mm nozzle with a 0.3 mm nozzle to get more detail out of some D&D miniatures I was printing and now my Z-offset is -0.750
Postato : 22/02/2020 1:28 am
RetroBill
(@retrobill)
@pete-b3
Thanks!
Postato : 22/02/2020 1:34 am
RetroBill
(@retrobill)
@frankincell
Thanks!
Postato : 22/02/2020 1:35 am
Pagina 114 / 241
