RE: Welcome to our new forum! Feedback here!
How can I post .3mf files to the forum on troubleshooting MK3S prints?
Put them into a zip file.
Feature request: Is it possible to add the number of collections a print has been added to in the title.
That is, where the comments tab has (10) next to it to indicate 10 comments, could we add (X) next to the Collections title to indicate how many collections a print has been added to without having to click on it.
WordFence is not allowing posts of plain text ... ?
any idea how to change the maildress?
regards,
Max
edit: spoke with support. Sadly its not possible at the moment ☹
Reproducible bug
Make a project set with multiple objects.
reload from disk. This works fine.
save project set
reload from disk. Imports all of the objects on the plate.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Hello, I've been using the notify by email option to follow the threads I'm interested in but the last weeks the links to the articles sent in the email point to the https://forum.prusa3d.com/forum/ (Chech main page) instead to the new posting -- why is that?
I thought for a while it was because the poster of the new article deleted there posting, but I have found that that is not the issue...
Mini with FW:4.4.1 + SuperPINDA + Bondtech Heatbreak + PC4-M8 couplers + 1 piece boden
Hello All,
I have received my first ever 3D printer today. Also I am joining to the Forum for tips and tricks.
Currently I am working with IT (already 30 years) and Now I am studying to Bachelor of Mechanical engineering. In school we are now going through different manufacturing techniques, and from there I got interest for 3D-printing.
I am finnish, but currently living in Germany.
Is there any plan for a feature to mark all topics in a SUBforum as read?
DJ
Hi all,
welcome to our new forum! Let me share some more details about the whole transfer.Our old forum ran on phpBB, which was handy in the beginning, but later on, as the user base increased, it became almost impossible to use it on the backend. Over 120 000 user accounts and many tweaks/hacks on the background to keep it running. Constant fixing took hundreds of hours.
With the Prusa Printers and single sign-on feature (OAuth). We stumbled again on the limit of the platform. Therefore we decided to look for another more flexible and up-to-date system.
I'm sure we are on the right track to improve the forum experience and there are more changes to come. In case you are missing some features from the old forum or you find any bugs, please let me know in the comments.
P.S.: Don't forget to check our brand new community website for sharing your 3D models prusaprinters.org
@joe-m14
I'm sure I'm not using this forum right... I clicked on the first button I could find to send a message to anywhere. I think the forum is difficult to navigate and not intuitive at all but that's not why I'm writing.
I recently got new drivers and firmware for my MK3S and now I cannot open Prusaslicer. I get an error message that says something about "unhandled" I would happily run old software if I could find some. In the unlikely event that this gets answered... thanks in advance
@joe-m14
@Joe-m14
For navigation, choose the little "home" icon in the upper left of the forum page, and then choose the appropriate sub forums from there. There's a specific i3-mk3s sub forum with a hardware/software/firmware subforum under there. You're more likely to get more eyeballs on your question there. Good luck!
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/
Austin, Texas, USA
@billplein
Thanks for your response. I tried to add a new topic and I got an error 403 saying something about how it was potentially unsafe. Is it just me or is this a very unpleasant website to deal with?
Hi Gents,
Have you been experienced any issues with the colorprint dxf generator here: https://blog.prusaprinters.org/color-print_3993/
I cannot add changing layer so this helpful tool is not working for me.
Thanks,
Adam
Hi Adam,
How are you trying to access this feature...
It Seems to work for Me!
I have selected the height at which the letters start on the right and then clicked on the '+' sign in the scroll bar, to set the colour change.
I have included the .3mf file, in a zip file, below
Regards Joan
@billplein
I haven't run into those problems but maybe the admins are using new tools. I was having an issue logging in yesterday, every time I logged in, if I came back to the site, I was logged out. Then again I am using some privacy tools in my browser so I expect issues now and then.
Austin, Texas, USA
Probably been said already, but the time to be able to edit a post needs to be extended to at least 24hrs or so.
You don't realise you made a mistake till someone else pulls you up on it and then it's to late to fix it.
Is this the appropriate place to request improvements to the Prusa Prints site? I would like to suggest the following:
When uploading files, the filenames are set all lowercase regardless of how the original file was named. This is a problem for two reasons. First, upper/lower case is often used in filenames for improved readability. For example, FileOne and FileTwo are more clear than fileone and filetwo. Second, for those of us who are using Linux, upper/lower case matter in file names - in Linux FileOne and fileone are two different files; changing case in filenames could result in files being accidentally over-written.
Another suggestion: Some projects require a large number of files. It would be useful if files could be uploaded to directories so that they could be more clearly organized.
Final suggestion: How about making it much more clear as to where problems and suggestions should be made. Ideally there should be forum topics for just this purpose. This would help prevent duplicate suggestions. A system for up-voting suggested improvements would also be very useful.
