Prusa Mini Clone from China
Page 10 / 18
RE: Prusa Mini Clone from China
Posted by: @crawlerin
Aaaand anothe thing discovered when I wanted to assemble it ... T nuts that attach XZ to Y don't fit into printed plastic parts of electronics enclosure. They are like 1 mm longer than notches on printed part (which can be fixed), and part protruding from extrusion is too thick (which is something that cannot be easily fixed). When screwed all the way in, they don't grip onto extrusion because of their thickness and whole part can easily slide around despite both side screws being tightened all the way. I don't want XZ just hanging on one single top screw. I will have to grind those down, as well as ridge on the plastic box to more reasonable thickness as I don't have spare matching M3nE nuts.
This whole clone really looks like "randomly sourced cheap parts thrown together, it looks similar, it should work". Definitely not for beginners, even if you dare to order it, be prepared to source your own parts anyway.
That is 100% certain - this should not and cannot be your first printer!
Posted : 26/10/2020 3:34 pm
vintagepc
(@vintagepc)
I've noticed that support chat from PR now asks you for the printer serial number. I'm betting that's partially to help combat providing support for cheap clones and wasting time trying to diagnose issues like this...
Posted : 26/10/2020 3:58 pm
@vintagepc
Probably.  There are ways around that if you integrity is in question.  Mine is not.
Posted : 26/10/2020 4:51 pm
Crawlerin
(@crawlerin)
@vintagepc
That's expected, their inventory system should be able to track it down to components and who packed them. Don't they do it for MK3S already?
Anyway, this printer makes me more frustrated that I initially expected, and I am pretty patient person when it comes to assembling stuff. It's always something discovered in next step that needs some workaround - which would be fine and expected had I sourced everything myself, but this was sold as a kit, I expect at least some compatibility with its own parts.
If you are tight on budget and find original MINI expensive, definitely go with something from Creality, Big Tree Tech or Artillery than these clones.
Posted : 26/10/2020 5:09 pm
Prusa question about the serial number is easy to understand. Who wants to give expensive and complex support for cheap clonware. Imagine you had your own company - would you offer support for third-party products?
Posted : 26/10/2020 7:36 pm
They have never asked my my serial number.  I have them on my account I guess.
Posted : 26/10/2020 7:41 pm
vintagepc
(@vintagepc)
Interesting, it was one of the fields I had to enter when starting a chat, along with order # etc
Posted : 26/10/2020 7:47 pm
@vintagepc
I always read that as my order number.
Posted : 26/10/2020 7:49 pm
Nikolai
(@nikolai)
Posted by: @charles-h13
The one case where I had an RMA on one part, they asked for the order #. Based on that they can pull any information from it.
I think it depends on the question. Sometimes it's easier to just answer it. Serial # lookup also takes time. Maybe they introduced this additional step in the support to minimize the flood of the support requests for non-prusa products. Maybe they had recently more cases where after long discussions with the customer and after providing pictures, videos they realize it's not an original Prusa printer. Usually a support process is being modified every time based on the requests they get. Asking for serial # as a first step reduce some load from the support team, so the actual customers can be served better.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 26/10/2020 7:53 pm
Serial Number (or order number) equals ship date equals warranty status equals help or not help.  Simple enough logic for any business.
Posted : 26/10/2020 7:57 pm
@tim-m30
They have always tried to assist me regardless of the order date.
Posted : 26/10/2020 8:41 pm
I am waiting for more square nuts.  I used them to assemble my printer and now I can't get them out of my prints.
Posted : 28/10/2020 1:20 am
vintagepc
(@vintagepc)
@vintagepc
It was an explicit separate field this time, order number and serial number.
It's still there, just under 'Product' and above 'printer type'.
Posted : 28/10/2020 1:45 pm
@charles-h13
The square nuts are sometimes really difficult to remove. The things are quite cheap and for this reason I always have a large stock of the M3, M4 and M5 variants (like this one) in stock.
Posted : 28/10/2020 5:23 pm
@karl-herbert
I have been cussing all night that I ran out.
Posted : 28/10/2020 5:32 pm
Zoltan
(@zoltan)
Member Moderator
SerIal number registering can also be used to count how many support has been required per particular printer. Each support case should be registered for particular printer for printer history registration.
Knowing the printer issues history can help you resolving the present issue.
Posted : 29/10/2020 10:29 am
Zoltan
(@zoltan)
Member Moderator
@tim-m30
Well known customers are brobably well known. 😉
Posted : 29/10/2020 10:34 am
@zoltan
Being well known is not always a bad thing.  Infamous is another thing.
Posted : 29/10/2020 10:54 am
This weekend will be photo fest of my build.  I have it running now.  I reprinted some parts with PETG and the grinding and squeaks stopped.
Posted : 30/10/2020 12:42 pm
Rat_Patrol
(@rat_patrol)
Only $100 less for a clone of unknown quality and materials, and the way it sounds completely un-assembled?
Hard pass from me.
But I already have a first run Mini 😀
Posted : 30/10/2020 4:06 pm
Page 10 / 18
