problems with circular surfaces
Andreas
(@andreas-5)
Hello, maybe somone has a solution. I export a stl file and import it in the prusa slicer. Unfortunately I get a circle which is build with several straight sections. And it is printed the same way how it is shown in the prusa slicer. I design the models with autodesk inventor 2024 pro.
Posted : 03/02/2024 3:38 pm
RE: problems with circular surfaces
Circles are typically created as a series of straight lines, the level of definition, defines how obvious the segments are
Think Low Poly, Obvious segments  -  Hight Poly, les obvious Segments Look to see if you can change the level of definition
In my 3d program, the control is called Mesh Tesselation
Posted : 03/02/2024 5:26 pm
