					                		print fan is not spinning error - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/</link>
                <lastBuildDate>Tue, 12 May 2026 09:49:21 +0000</lastBuildDate>
                        <title>RE: print fan is not spinning error</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729910</link>
                        <pubDate>Sun, 15 Dec 2024 21:30:44 +0000</pubDate>
                        <description><![CDATA[reported to]]></description>
                        <content:encoded><![CDATA[<p>reported to https://github.com/prusa3d/PrusaSlicer-settings/issues/282</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729910</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729891</link>
                        <pubDate>Sun, 15 Dec 2024 18:27:55 +0000</pubDate>
                        <description><![CDATA[Some profiles lag behind the firmware versions, which started to require certain minimum values, such as fan speed.
IL check on GitHub because this starts to be an issue because some preset...]]></description>
                        <content:encoded><![CDATA[<p>Some profiles lag behind the firmware versions, which started to require certain minimum values, such as fan speed.</p>
<p>IL check on GitHub because this starts to be an issue because some presets are just old.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729891</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729846</link>
                        <pubDate>Sun, 15 Dec 2024 10:42:49 +0000</pubDate>
                        <description><![CDATA[Thanks.
That reminds me, that those fan errors appeared after I changed filament to PM FRJet (Before, I was printing using Prusament only).
But I use the official PM FRJet filament profile...]]></description>
                        <content:encoded><![CDATA[<p>Thanks.</p>
<p>That reminds me, that those fan errors appeared after I changed filament to PM FRJet (Before, I was printing using Prusament only).</p>
<p>But I use the official PM FRJet filament profile delivered by Prusa. Indeed, it has a fan speed range of 5-15%, while Prusament PETG profile has 30-50%.</p>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Michal Bartak</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729846</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729839</link>
                        <pubDate>Sun, 15 Dec 2024 09:15:18 +0000</pubDate>
                        <description><![CDATA[I had that fan issues with a Fiberology filament, the fix is to increase minimum fan speed in filament profile, see]]></description>
                        <content:encoded><![CDATA[<p>I had that fan issues with a Fiberology filament, the fix is to increase minimum fan speed in filament profile, see https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/hotend-fan-not-spinning-check-it-for-possible-debris-then-inspect-the-wiring-error/#post-726328</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729839</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729809</link>
                        <pubDate>Sat, 14 Dec 2024 18:54:19 +0000</pubDate>
                        <description><![CDATA[I do not have the Mini, but my MK3 has been running fine with the fan check disabled for maybe three years or so.  I just got tired of the (false) alarms/aborts that some glitch is causing.]]></description>
                        <content:encoded><![CDATA[<p>I do not have the Mini, but my MK3 has been running fine with the fan check disabled for maybe three years or so.  I just got tired of the (false) alarms/aborts that some glitch is causing.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>jsw</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729809</guid>
                        <title>print fan is not spinning error</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729803</link>
                        <pubDate>Sat, 14 Dec 2024 18:26:43 +0000</pubDate>
                        <description><![CDATA[Recently I encountered this error &quot;print fan is not spinning&quot; error twice. It caused immediate print interruption.The error is displayed on the control panel. The Print Fan did not spin inde...]]></description>
                        <content:encoded><![CDATA[<p>Recently I encountered this error "print fan is not spinning" error twice. It caused immediate print interruption.</p><p>The error is displayed on the control panel. The Print Fan did not spin indeed. Attempts, with use of a finger, to make it work give no results.</p><p>But turning the printer off and on again, makes the fan spin again.</p><p>On the Internet, I found suggestions to disable fan check. </p><p>Is it a known issue? Does that mean that the fan deserves replacing? Or it's software problem?</p><p>Edit: I disabled Fan control and started the next print. After some while I found that the Print Fan is not spinning. In the control panel, in tuning section I found it's turned off. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-fan-is-not-spinning-error/#post-729803</guid>
