MINI enclosure? IKEA?
Stránka 5 / 6
Seth
 Seth
(@seth-2)
RE: MINI enclosure? IKEA?
What is the practical maximum length for the cables in the MINI.
Asking as I am contemplating mounting the control box outside an enclosure and extending the cables.
Napsal : 09/02/2020 6:14 pm
ScoutStorm
(@scoutstorm)
Bioluminous
@seth-f2
I have a MK3S I use exclusively for polycarbonate inside an insulated fire-resistant enclosure. I started with just the PSU outside but now have everything outside as the enclosure temp hovers around 50ºC. I estimate I added about 18 inches to all of the wires. I just spliced them - I did not use connectors. If I did it again I would make the wires longer so I could remove the printer more easily from the enclosure when it needs servicing. So at least in my case, 18 inches has created no issues at all.
Napsal : 10/02/2020 1:11 am
Seth
 Seth
(@seth-2)
@shrikestorm
Thanks, I will probably use connectors for ease of servicing.
Napsal : 10/02/2020 2:21 am
towlerg
(@towlerg)
The idea of an easily de-mountable encloseure looks pretty attractive if PSU and Control box mounted outside enclosure.
Napsal : 10/02/2020 3:14 pm
I really would like to find a good enclosure.  I have 5 printers and need 3 more enclosures.
Napsal : 10/02/2020 3:28 pm
diddzw
(@diddzw)
So my Mini arrived last week but before it had arrived i took the advice from this thread to build a 44cm Cube.. risky but..
the outcome works very well!
The cube has space for the printer and spool holder.
Prusa Mini enclosure
Napsal : 19/03/2020 7:11 am
3 lidem se líbí
Deniel Home
(@deniel-home)
The housing depends on the size and content. I would be interested to find suitable IKEA accessories.
Napsal : 19/03/2020 12:16 pm
MichaelR64
(@michaelr64)
Posted by: @diddzw
Cool, where did you get this?
Napsal : 28/03/2020 7:20 pm
diddzw
(@diddzw)
@mreitsma
I built it from standard parts you can order from many webshops that supply Aluminium profiles. The build is based on 2020 Al profiles 44cm cube. Walls are plexiglass i had cut in my local hardware shop.
Napsal : 28/03/2020 7:43 pm
1 lidem se líbí
Dorus
(@dorus)
This is what you call a snug fit.
a prusa mini in a ikea milsbo display cabinet.
Napsal : 28/03/2020 8:30 pm
1 lidem se líbí
atomleef
(@atomleef)
@karl-herbert
this is super cool
  https://grabcad.com/library/3d-fdm-printer-1
thanks
Napsal : 30/03/2020 4:36 am
atomleef
(@atomleef)
@dorus
box and storage within wow
Napsal : 30/03/2020 4:37 am
atomleef
(@atomleef)
my budget option 🙂
This post was modified před 6 years by atomleef
Napsal : 30/03/2020 4:41 am
atomleef
(@atomleef)
@dorus
where can you find have black mini edition?
Napsal : 30/03/2020 4:46 am
Dorus
(@dorus)
@atomleef
you can select if you want a full black mini or black and orange.
Napsal : 30/03/2020 9:20 am
1 lidem se líbí
atomleef
(@atomleef)
@dorus
thanks
Napsal : 30/03/2020 10:10 am
DarthToombs
(@darthtoombs)
@crawlerin
Ah, it it the z axis motor? Wondering if I could rout a couple of mm out of the top of my Kallax cube to squeeze it in. If it’s too much I’ll probably put it under the lack enclosure.
Napsal : 01/04/2020 12:15 pm
Crawlerin
(@crawlerin)
@byron-t
That may be interesting.
Next printer from Prusa: Prusa MICRO. Designed to fit exactly into Kallax compartment. Ideal for schools, fit 16 printers into 1 4x4 Kallax shelf unit to have whole classroom covered.
Napsal : 02/04/2020 11:18 pm
GrimmWinters
(@grimmwinters)
@mreitsma
and the upper cables aren't pinched, wenn it moves to the highest position?
because that's a tiny footprint, awesome 🙂
Napsal : 03/04/2020 10:12 am
Crawlerin
(@crawlerin)
Posted by: @atomleef
@dorus
Alternatively, you can print plastic parts in PETG of any color you like (... or find).
https://github.com/prusa3d/Original-Prusa-MINI
Napsal : 03/04/2020 5:27 pm
Stránka 5 / 6
