Low Extruder "Grab" on Filament
Colton Campbell
(@colton-campbell)
Lately I have had extrusion issues on my Mini, where the extruder drive gear slips on the filament. It seems to slip much easier than it used to, where slight tension on the spool winding will cause extrusion to stop, and then restart once bind is released. I have tried tightening and loosening idler tension and can't figure out if I am running it too tight or too loose. I have it just slightly tighter than what is recommended on the Mini setup documentation.
Any thoughts on what could be causing this and how to fix?
Postato : 13/11/2025 9:57 pm
Check the drive gear is clean - blow out any dust.
Then check whether the inside of the PTFE tubing has worn and is gripping the filament too much.
Postato : 15/11/2025 4:37 am
