					                		Extruder Tension Adjustment - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/</link>
                <lastBuildDate>Tue, 09 Jun 2026 05:56:59 +0000</lastBuildDate>
                        <title>RE: Extruder Tension Adjustment</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731059</link>
                        <pubDate>Sun, 29 Dec 2024 22:25:41 +0000</pubDate>
                        <description><![CDATA[Thank you! Yes, I did make a mistake. That link was exactly what I needed. Thank you again.]]></description>
                        <content:encoded><![CDATA[<p>Thank you! Yes, I did make a mistake. That link was exactly what I needed. Thank you again.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>sberesfo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731059</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731049</link>
                        <pubDate>Sun, 29 Dec 2024 21:34:21 +0000</pubDate>
                        <description><![CDATA[The link does address the Mini and Mini +.  It contains adjusting for a wide range of prusa printers as well as the MMU.  Please look again.
If you want to get more specific]]></description>
                        <content:encoded><![CDATA[<p>The link <strong>does</strong> address the Mini and Mini +.  It contains adjusting for a wide range of prusa printers as well as the MMU.  Please look again.</p>
<p>If you want to get more specific https://help.prusa3d.com/article/idler-screw-tension_177367#mini-mini</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Neophyl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731049</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731040</link>
                        <pubDate>Sun, 29 Dec 2024 19:23:59 +0000</pubDate>
                        <description><![CDATA[Hi, The link you provided does not address the mini+. We want to reduce the pressure the extruder gear is squeezing the filament. This is very easy to do on the MK3S and we are curious if th...]]></description>
                        <content:encoded><![CDATA[<p>Hi, The link you provided does not address the mini+. We want to reduce the pressure the extruder gear is squeezing the filament. This is very easy to do on the MK3S and we are curious if there is a similar adjustment on the mini+.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-731040</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-730997</link>
                        <pubDate>Sun, 29 Dec 2024 07:03:51 +0000</pubDate>
                        <description><![CDATA[Do you mean idler screw on the side of the PTFE tube that goes into the extruder?]]></description>
                        <content:encoded><![CDATA[<p>Do you mean idler screw on the side of the PTFE tube that goes into the extruder? https://help.prusa3d.com/article/idler-screw-tension_177367</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-730997</guid>
                        <title>Extruder Tension Adjustment</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-730989</link>
                        <pubDate>Sun, 29 Dec 2024 02:17:40 +0000</pubDate>
                        <description><![CDATA[Hello,I am curious if there is a way to adjust the extruder tension against the filament on the Mini+.Thank you,Scott]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p>I am curious if there is a way to adjust the extruder tension against the filament on the Mini+.</p><p>Thank you,</p><p>Scott</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/extruder-tension-adjustment/#post-730989</guid>
