Extruder rear replacement - spring and brass PTFE Fitting piece
Arni_Pi
(@arni_pi)
Hi all,
I made the mistake of over-tightening the extruder rear's M3x40 screw (the tightening screw with the spring on it) and then the screw got completely stuck and I cannot remove it at all (it just keeps turning forever). My conclusion was to completely replace the extruder rear, so I bought a replacement part. However, I was unaware that the M3x40 screw had a spring on it and that the brass PTFE Fitting piece (the piece that fits into the extruder rear and holds the PTFE tube) is not included. I have three questions:
  1. Is there somewhere I can buy the spring that fits on the M3x40 screw?
  2. Is there a guide on how to fit the brass piece (that holds the PTFE tube) into the extruder rear? I searched your database but cannot find! I saw previous comments in the guide that this brass piece is pre-installed in the Extruder rear but that is not true.
  3. I'm assuming I can remove the brass piece from the existing damaged extruder rear and reuse it in the new extruder - are there any other pieces I might need?
Thanks so much to any responses - I am a total beginner so appreciate any insight you might have.
Thank you!
This topic was modified 1 year ago by Arni_Pi
Posted : 26/01/2025 7:21 pm
mirek454
(@mirek454)
RE: Extruder rear replacement - spring and brass PTFE Fitting piece
https://help.prusa3d.com/guide/3-x-axis-extruder-assembly_199519#200776
Chapter 35
Please excuse my writing style.
I am from the Czech Republic, I don't speak English, I translate using Google Translate
Posted : 05/03/2025 8:19 am
mirek454
(@mirek454)
The spring should work from a pen. Try different ones, there must be play in the hole and on the screw.
Posted : 05/03/2025 8:27 am
