					                		Better quality? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/</link>
                <lastBuildDate>Fri, 12 Jun 2026 08:46:09 +0000</lastBuildDate>
                        <title>RE: Better quality?</title>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-791027</link>
                        <pubDate>Fri, 01 May 2026 10:52:38 +0000</pubDate>
                        <description><![CDATA[Those pictures are for a single layer? If so then you z offset is still too high, it should be squished and smooth on both sides. What about the photos from both sides?I would also recommend...]]></description>
                        <content:encoded><![CDATA[<p>Those pictures are for a single layer? If so then you z offset is still too high, it should be squished and smooth on both sides. </p><p>What about the photos from both sides?</p><p>I would also recommend to do a general printer maintenance check especially for short and long PTFE tubes.</p><p>The through explanation is under https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/how-often-to-replace-various-parts-on-the-mini-a-proposed-regular-part-replacement-schedule/</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-791027</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-791023</link>
                        <pubDate>Fri, 01 May 2026 10:21:48 +0000</pubDate>
                        <description><![CDATA[The filament is still not dry.The first layer &#039;Z&#039; offset is probably OK for a smooth sheet but textured print sheets need a fraction more &#039;squish&#039; than smooth ones.The poor adhesion looks li...]]></description>
                        <content:encoded><![CDATA[<p>The filament is still not dry.</p><p>The first layer 'Z' offset is probably OK for a smooth sheet but textured print sheets need a fraction more 'squish' than smooth ones.</p><p>The poor adhesion looks like the result of a dirty print sheet - but it's hard to be certain with damp filament, it won't hurt to give the sheet a thorough clean.</p><p>White/pastel filaments are always trickier to print with than natural/dark colours.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-791023</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790975</link>
                        <pubDate>Thu, 30 Apr 2026 19:06:33 +0000</pubDate>
                        <description><![CDATA[Forget GCODE, looks you&#039;re getting there. @_KaszpiR_ posted official instructions above, that may be worth a read. My advice is generic, not for this particular printer.If you want to print ...]]></description>
                        <content:encoded><![CDATA[<p>Forget GCODE, looks you're getting there. </p><p>@_KaszpiR_ posted official instructions above, that may be worth a read. My advice is generic, not for this particular printer.</p><p>If you want to print test chips like the one you're holding (and maybe half the size then it's four times faster), you may slice for a lower layer height just to set Z-offset (it gets more sensitive so the change from Z offset is observed more clearly). When happy with the result, print the object with the original layer height, Z offset remains unchanged.</p><p>And did I mention, dry (and I mean "really" dry) filament matters...</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>mnentwig</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790975</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790970</link>
                        <pubDate>Thu, 30 Apr 2026 18:34:57 +0000</pubDate>
                        <content:encoded><![CDATA[<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/04/48a7d6d3-image-scaled.jpg"><img class="alignnone size-medium wp-image-186172" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/04/48a7d6d3-image-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Jullicca</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790970</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790969</link>
                        <pubDate>Thu, 30 Apr 2026 18:33:35 +0000</pubDate>
                        <description><![CDATA[this is with z 1.570 and 250 C]]></description>
                        <content:encoded><![CDATA[<p><br />this is with z 1.570 and 250 C </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790969</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790968</link>
                        <pubDate>Thu, 30 Apr 2026 18:28:47 +0000</pubDate>
                        <description><![CDATA[how can i print that with only the gcode]]></description>
                        <content:encoded><![CDATA[how can i print that with only the gcode]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790968</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790965</link>
                        <pubDate>Thu, 30 Apr 2026 18:17:10 +0000</pubDate>
                        <description><![CDATA[I recommend to read/watch this for quick and easy way to improve first layer/offset setup]]></description>
                        <content:encoded><![CDATA[<p>I recommend to read/watch this for quick and easy way to improve first layer/offset setup https://www.printables.com/model/107639-first-layer-calibration-prusa-mini</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790965</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790963</link>
                        <pubDate>Thu, 30 Apr 2026 18:16:33 +0000</pubDate>
                        <description><![CDATA[oh, and ideally done at printing temperature (thermal expansion) but be aware that 260 degrees on the same spot will burn a hole into the print plate. 150 °C should be a safe compromise.]]></description>
                        <content:encoded><![CDATA[<p>oh, and ideally done at printing temperature (thermal expansion) but be aware that 260 degrees on the same spot will burn a hole into the print plate. 150 °C should be a safe compromise.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790963</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790960</link>
                        <pubDate>Thu, 30 Apr 2026 18:11:20 +0000</pubDate>
                        <description><![CDATA[Sanity check: Use a standard sheet of printer paper (80 grams / squaremeter). Move head to Z=0.1 mm = 100 µm. Set Z offset so the nozzle causes some friction on the paper which gets stronger...]]></description>
                        <content:encoded><![CDATA[<p>Sanity check: Use a standard sheet of printer paper (80 grams / squaremeter). Move head to Z=0.1 mm = 100 µm. Set Z offset so the nozzle causes some friction on the paper which gets stronger when you place a finger on the head, pushing down slightly (my routine from a "dumb" Klipper printer without wizards). That's how I align toolchanger nozzles, typically going down a few 10µ steps printing 1-minute test chips after the paper "coarse alignment".</p>
<p><em>Edit not sure if the Prusa GUI allows 0.1 mm, might be hard without GCODE command line. You could set Z=0.000 mm and do the above alignment, then move down by 100 µm.</em></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790960</guid>
                        <link>https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790958</link>
                        <pubDate>Thu, 30 Apr 2026 18:07:29 +0000</pubDate>
                        <description><![CDATA[My z offset was 1.295]]></description>
                        <content:encoded><![CDATA[<p>My z offset was 1.295 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/better-quality/#post-790958</guid>
