Assembling a new Millink i3 MK2 with a problem
ktbird54
(@ktbird54)
I'm attaching the PSU power unit and the holes on the side for the M4 screws are not lining up with holes in the vertical aluminum frame member if I place on top of the PSU-y part mounting bracket. Or visa-versa if I attach M4 screws first then the PSU base mount is below the PSU-y part.
Any suggestions?
Publié : 10/12/2019 12:22 am
Greybeard3D
(@greybeard3d)
RE: Assembling a new Millink i3 MK2 with a problem
This forum is for a Prusa Mini. Not an i3.
Publié : 10/12/2019 12:43 am
Crawlerin
(@crawlerin)
Hello,
I think you may be posting on the wrong forum, this is for Prusa MINI printers. You may want to post it under the MK2 section of this forum here.
This probably isn't original Prusa printer, you may want to contact manufacturer's support to check what's going on. Helping people with not genuine Prusas is at individual forum members discretion.
Is the printer supposed to be 1:1 clone? If yes, follow assembly instructions for correct printer (MK3, MK2, MK2S... whichever this is clone of). https://manual.prusa3d.com/c/English_manuals which step is giving you difficulty? Maybe you have it on the wrong side of frame.
If not, you should have manual attached in some shape or form with the kit, could be on SD card, USB stick or online at manufacturer's web page.
Ce message a été modifié il y a 6 years par Crawlerin
Publié : 10/12/2019 1:00 am
