5.1.0-alpha1 Firmware for Original Prusa MINI/MINI+ with Input Shaper and Prusa Connect!
Strona 2 / 8
Tom_3D
(@tom_3d)
Wow with this news i´m super excited to try ! Prusa teams are best i don´t expected they put new fast IS, PA etc from MK4 !
Thanks a lot !
Díky borci!
Opublikowany : 19/09/2023 9:22 am
1 ludzie polubili
Pitel
(@pitel)
RE: 5.1.0-alpha1 Firmware for Original Prusa MINI/MINI+ with Input Shaper and Prusa Connect!
Please add 0.6 nozzle support to the slicer. 🙏🏻
Opublikowany : 19/09/2023 11:33 am
2 ludzie polubili
Werner-Sellschopp
(@werner-sellschopp)
Thankyou for this amazing peace of firmware. Works nearly perfect.
But the Bonkers-Benchy, printed in 18 minutes, had a little bit of underextrusion. The same benchy, printed in 40 minutes with the included settings, had a perfect finish.
Opublikowany : 19/09/2023 11:45 am
Werner-Sellschopp
PS:
... I think, 40 minutes is fast enough
Opublikowany : 19/09/2023 11:51 am
1 ludzie polubili
Kaspervm
(@kaspervm)
That just happened to me. I sliced the file again and now it is printing. 1. layer going down.
Could it be the timestamp from installing the firmware / creating the file in the slicer? -i have no idea...
Opublikowany : 19/09/2023 12:04 pm
PGe-10
(@pge-10)
Now I can't get it in my amateur head, don't I need to connect an extra sensor to be able to run Input Shaper on Mini+ printer???
Opublikowany : 19/09/2023 12:44 pm
1 ludzie polubili
Nope.
Posted by: @pge
Opublikowany : 19/09/2023 1:22 pm
For some reason, I cannot get this to install on one of my Minis.  Do I need to change to file name?
Opublikowany : 19/09/2023 1:23 pm
PGe-10
(@pge-10)
Have you read this? Can it help?
Firmware update instructions
Make sure you are running firmware 4.4.1, see the release notes for firmware files and instructions. Once the 4.4.1 is installed proceed to flashing the 5.1.0-alpha1 firmware. Note that the upgrade might take longer than usual
Opublikowany : 19/09/2023 1:35 pm
horza
(@horza)
last line in known bugs section on the release page says:
In rare cases the printer might have issues with homing, a temporary fix is to hold the print head for a while while homing
So that's what I did - while selftesting X, I held the head stuck to the extruder so it can't "bounce" back for 2 seconds. Released it after 2 seconds and it continued testing X axis and everything else just fine.
Opublikowany : 19/09/2023 1:37 pm
1 ludzie polubili
Yes, and I have 4.4.1.  Do not assume someone did not read the instructions.  One of my printers is just not acknowledging the firmware file is on the thumb drive.  I have it on one and I guess I will try a third printer instead.
Posted by: @pge
This post was modified 2 years temu by cwbullet
Opublikowany : 19/09/2023 1:41 pm
PGe-10
(@pge-10)
I'm very sorry, I meant no harm. On the contrary, I wanted to try to help
Opublikowany : 19/09/2023 1:48 pm
I appreciate that.  I am not sure about what is causing it.  One printer worked.  One went into a perpetual boot loop when I tried to update to 4.4.1.  A third would not recognize the input shaper firmware.  I guess that means I will be trying a fourth tonight.
Posted by: @pge
Opublikowany : 19/09/2023 1:52 pm
SuperJudge
(@superjudge)
Posted by: @pitel
Whimpers in Bondtech CHT 0.5mm
Mini+: Bondtech extruder, Bondtech throat, Input Shaper firmware -- XL: single toolhead, Bondtech CHT 0.6mm, Input Shaper firmware
Opublikowany : 19/09/2023 1:57 pm
timovp
(@timovp)
Seconding this. For now, swapped the nozzle and started a first print
Posted by: @pitel
Opublikowany : 19/09/2023 1:59 pm
PGe-10
(@pge-10)
I only have 2 Mini+ so I only dare to test it on one, after all it's only an Alpha version and I'm not brave enough to dare to run on both
Posted by: @cwbullet
Posted by: @pge
Opublikowany : 19/09/2023 2:06 pm
kevman
(@kevman)
still having homing issues. I checked the belt tension with the tool, I tried some suggested commands from the bug page on github:
M914 X140
G28 X
That worked , but when I started the print it failed again with the homing error.
Opublikowany : 19/09/2023 2:09 pm
Smiley85
(@smiley85)
  • Ah my fails the y axis test. Reverted back to 4.4.1 and it's fine. Upgraded back to this alpha and it fails again.
This post was modified 2 years temu 2 times by Smiley85
Opublikowany : 19/09/2023 2:18 pm
Neolker
(@neolker)
Belts must be tune pretty well for Input Shaper: https://belt.connect.prusa3d.com/
Opublikowany : 19/09/2023 2:40 pm
Smiley85
(@smiley85)
Posted by: @neolker
That's a pretty cool feature. I just tried and both x and y were fine.
Opublikowany : 19/09/2023 3:22 pm
1 ludzie polubili
Strona 2 / 8
