4.1.0 Firmware for Original Prusa MINI
Page 3 / 4
enganear
(@enganear)
RE: 4.1.0 Firmware for Original Prusa MINI
@zoltan
Any update?
Publié : 05/08/2020 2:40 pm
Zoltan
(@zoltan)
Membre Moderator
Hi @stephen-c32
Sorry time ,is running faster and faster,
I am looking at your g-code - did you change the extruder to bondtech?
I see you have added some G-code into the initial part of the G-code file. Did you put anything at the final part? I guess not.
Did you do by chance any changes on printer between 4.0.5 and 4.1.0?
Which 4.1.0 did you use please? RC or final? - edit. sorry, I found it
Finishing my print in half an hour, I will check yours.
Publié : 05/08/2020 3:03 pm
Zoltan
(@zoltan)
Membre Moderator
In 12 minutes I will have the testing result
Publié : 05/08/2020 4:34 pm
Tracy
(@tracy)
Posted by: @zoltan
Please let it be good. I'm still using 4.0.2 because every version since has had something wrong with it.
Publié : 05/08/2020 4:55 pm
Zoltan
(@zoltan)
Membre Moderator
I can confirm, your G- code is doing that way you described.
I have checked a simple print without any inserted g-code in the print file and it worked without issue, going to check your code in other version.
Can you please share your .3mf file?
Publié : 05/08/2020 4:56 pm
Zoltan
(@zoltan)
Membre Moderator
@stephen-c32
are you sure, that betwen 4.0.5 and 4.1.0 you did not do any change in that G-code file?
Posting Your .stl file would be appreciated
Publié : 05/08/2020 5:16 pm
Zoltan
(@zoltan)
Membre Moderator
Flashed  4.05. and it ends correctly, I would need your .3mf file to see the differences of the standard and your setup.
Thanks
Publié : 05/08/2020 7:29 pm
Malcolm
(@malcolm)
@stephen-c32
I know zoltan saw and is currently investigating. But I have the exact same issue as you, I posted a thread here: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/immediately-after-successful-print-mini-goes-into-mesh-bed-leveling-procedure/
My printer used to try and Mesh Bed Level but now after it parks it returns to the home (bottom right corner) by moving the z and y axis at the same time. Just like yours but a different corner. Maybe read my post and see if any similarities jump out to you.
@zoltan maybe you can give us a 'clean' gcode file for us to test on our machines?
Publié : 06/08/2020 12:26 am
Zoltan
(@zoltan)
Membre Moderator
@stephen-c32
we suspect the M92 used for bondtech e- step, you are using. Team is working on it.
Try the code without this M92 if it works.
Thanks
Publié : 06/08/2020 1:13 pm
Crawlerin
(@crawlerin)
@zoltan
Bondtech extruder is one of the most common upgrades people buy because it's just drop-in (one can fit non-MINI specific extruders too but it requires more work). It would not be good if this was causing the issue, you need to change e-steps.
Publié : 06/08/2020 3:27 pm
Malcolm a aimé
enganear
(@enganear)
I see FW 4.2.0 has been released. Does this release have any fix for my issue?
Publié : 23/08/2020 8:29 pm
bobc
 bobc
(@bobc)
This issue https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/733 - M92 command causes weird behaviour? No fix yet.
Publié : 23/08/2020 8:46 pm
3dpenguin
(@3dpenguin)
This problem also is with 4.2.0 and I even do not have a Bondtech extruder and do not use M92. The printer is as it has been delivered. Attached is the gcode I used to do some test prints wuerfel_0.2mm_PETG_MINI_5m.gcode
I put some 2s delays after each line of the Filament-specific end gcode (which has been removed again in the attached code), to see if one of the commands causes the unwanted movements at the end of the print, but none of them was the problem.
Going back to 4.05 and printing the same model did not show this behavior. The strange thing is, that I used a 4.2.RC1 software before, that worked, but I do not know the release number and now it is gone :(.
Publié : 27/08/2020 7:28 pm
Zoltan
(@zoltan)
Membre Moderator
@a-schwinn
can you please attach a videoto see what  your printer is doing?
Publié : 28/08/2020 10:33 am
3dpenguin
(@3dpenguin)
See video, at the end of the print, the print head moves to the parking position, which is the upper right corner in the video and see g-code. But then the bed moves back and the z-axis lowers, which is nowhere in the code and as already written, the same g-code but with 4.0.5 does not show this behavior.
Edit: Hope the video has been uploaded.
Ce message a été modifié il y a 4 years par 3dpenguin
Publié : 28/08/2020 3:45 pm
3dpenguin
(@3dpenguin)
I flashed today Buddy_4.2.1-final+2072.bbf from GitHub and the problem is gone now 🙂
Publié : 02/09/2020 7:46 pm
enganear
(@enganear)
@a-schwinn
That is awesome news! I have been stuck on 4.05 waiting for some attention. I guess they must have found something.
Stephen
Publié : 02/09/2020 9:49 pm
Zoltan
(@zoltan)
Membre Moderator
Miracles sometimes happen 😉
Publié : 03/09/2020 3:03 pm
enganear
(@enganear)
@zoltan
No miracles this time. I upgraded to 4.2.1 and the bad behavior returned. After parking, the head moves to the left and down, crashing into the bed if I do not stop it. I must reflash with 4.05. It is the last firmware to work for me.
Publié : 27/09/2020 11:38 pm
Zoltan
(@zoltan)
Membre Moderator
@stephen-c32
same Gcode?  with or without M92?
Publié : 28/09/2020 3:28 pm
Page 3 / 4
