4.0.4 Firmware for Original Prusa MINI
Hi guys,
this is the final release recommended to all users!
What is new?
- Jerk speeds fixed
Detailed description
This version of the firmware fixes rare scenarios of improper jerk speeds when Marlin does not accept the value stored in the emulated EEPROM.
Supported printers:
- Original Prusa MINI
Download link:
https://www.prusa3d.com/drivers/
How to flash the firmware on MINI:
- Copy the firmware file (.bbf) onto the USB drive with FAT32 formatting
- Insert the flash drive in the MINI's USB port
- Turn the printer ON (or reset it)
- A screen with update prompt will appear
- Confirm you want to flash the firmware
- Wait till the firmware is flashed and printer fully boots into the homescreen
Please report any bug here:
github.com/prusa3d/Prusa-Firmware-Buddy/issues
As always, we wish you happy printing and look forward to your feedback!
/ Knowledge Base
RE: 4.0.4 Firmware for Original Prusa MINI
404 firmware not found.
Please try it again, I just downloaded the firmware from the Prusa site without any issue.
/ Knowledge Base
@jakub-d
😆 it was feeble attempt to make fun of 404 HTTP response. Because this is 4.0.4 firmware. Sorry for confusion, I see myself out.
I was really hoping that with the next build we would get web support back 🙁 Someday hopefully soon lol.
could it be that even releases are only used to fix things and odd releases add functionality -- I have seen a lot ethernet/web stuff being fixed on github so I think we will have to wait for 4.0.5
Stock MK4S with FW 6.2.6
Successfully upgraded to 4.0.4 and reprinted my calibration cube. No more grindy sounds! Thank you so much for the help @jakub-d !
@oxygen
Usually this kind of version numbering (x.y.z) represents major, minor, patch, where major means huge overhauls/redesigns or additions that can often break compatibility with earlier versions, minor means feature additions and patch means bugfixes. Not sure how Prusa does it but that's the gist of how it's usually done.
The reason I was suggesting this is because my company uses the same method (in sprints of 2 weeks)
The next firmware release is already at works, expect a beta version soon 🙂
/ Knowledge Base
Is the inability to manually change the filament in the Pause/Tune/Change filament sub-menu at any arbitrary layer, i.e., without having to have a programmed pause point in the gcode file, a known bug, or do I simply not know how to do it? Please tell me how this works, or acknowledge the problem and discuss when it will be fixed. Thank you.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Looking for a place to share your creations and get help for your prusa printer, and get general 3D printing help? We have over 300 members and some great professional guiders that can help you! Join now!
@alfredwilliam0809
Reported as spam. Not relevant to the thread!
