The death of PLA, Long live the King
3d0zer
(@3d0zer)
Is PLA dying a slow death?
Outside the range colors, why would a sane person still print PLA?
- It will degrade over time due to UV
- It is weaker then PETG
- Price difference between PLA and PETG are gone
- Temperature resistance is amongst the lowest
Even for inside materials, used in the house, it would still make most sense to print in PETG right?
Dieses Thema wurde geändert Vor 15 hours von 3d0zer
Just a guy with a Core One L on a 3D Journey
Veröffentlicht : 12/06/2026 9:26 am
RE: The death of PLA, Long live the King
Define 'stronger', PLA is more rigid than petg and the price difference still exists.
Veröffentlicht : 12/06/2026 11:35 am
I find I'm printing more PLA than ever ... I keep black, white, grey, clear and a three or four colours, I can't quite get rid of them.
So does PETG
No, it is stronger than PETG but brittle and less shock resistant.
Sometimes but mostly wrong.
You missed a couple of things, the most important being the tendency to evade stress.
PETG is tougher and more flexible but PLA is better for precision parts and light mechanisms; it's also easier to paint if you really need colours.
I also use cheap PLA for most early prototypes even if the final print will use PETG or something more exotic.
Veröffentlicht : 12/06/2026 12:29 pm
You can print finer details with PLA vs PETG. This is good for features like Litophanes. It prints faster as well. I use PLA when I want to get a rough prototype out for sizing where the final product might be in ASA or a more expensive material. It's also super cheap. Then there are the "specialty" filaments like woodfill and metal which only come in PLA.
Veröffentlicht : 12/06/2026 1:44 pm
Ruebarb
(@ruebarb)
2nd Hyiger's post.
I would agrue, that PETG is actually on the way out. We have many types of ehanced PLA now, that have alot of great properties. Since we can all print CF, I see regular PETG having much less use, PETG-GF is you want to save $, since I can print abs-cf, PAs and soon PPA-CF. I don't plan on buying any more plain PETG. When using my MK3S, yes PETG was most of what I printed and PLA was minimal. The engineering filaments are now able to be printed, leaving PETG behind on every single property it offers.
Core One L MMU3, MK3S
Veröffentlicht : 12/06/2026 2:00 pm
And also add the PCTG runs circles around PETG. They are cousins so have a very similar print profile but the former doesn't string (as much) as PETG, definitely doesn't warp as much, is more impact and chemical resistant. More filament manufactures are jumping onto PCTG so I expect PETG usage to start to wane. The one downside is that it's still a bit more expensive than generic PETG but around the same price a Prusament PETG.
Diese r Beitrag wurde geändert Vor 10 hours von hyiger
Veröffentlicht : 12/06/2026 2:04 pm
Conrad
(@conrad-2)
We have every filament imaginable in our inventory at work and print all manner of things. We still print almost everything with PLA unless there's a good reason not to. About the only good reason is if we want to print an assembly fixture that needs to go in the oven. I question the UV issue. It's real, but I've had PLA parts outdoors for almost a year with no visible degradation. I worry more about color fading, but I've got orange Prusament PETG that's been outdoors and is still so bright it almost glows.
Veröffentlicht : 12/06/2026 2:09 pm
PLA should definitely not be exposed to direct sunlight because it will warp. I got into 3D printing to print brackets and adapters for my telescopes mostly using black PLA and most of them warped when I left my scopes outside. I had an Ender 3 at the time and knew nothing about plastics and their properties then. Other than PLA was what you used and that PETG was the "advanced" stuff. But then the Ender 3 could really only print those two. Maybe ABS/ASA but I wouldn't have known that then (6 years ago).
Veröffentlicht : 12/06/2026 2:26 pm
mnentwig
(@mnentwig)
Yes, on paper. I own two rolls of PLA and a stack of PETG spools almost to the ceiling (sounds dramatic but I keep almost-empty spools as samples. They stack nicely...)
Moisture absorption (=> stringing) and dimensional stability are the deciding factors, for me.
PLA creeps, warps, deforms and generally misbehaves at somewhat lower temperature than PETG. But at room temperature without extensive exposure to sunlight (it's not like it turns to dust at dawn) the material properties are fairly solid.
Veröffentlicht : 12/06/2026 3:02 pm
I find myself printing PETG less and less. Pretty much only when I need a bit more "flex" compared to PLA. These days it's mostly ASA for objects that are used outside the house and PLA inside. With some PCCF thrown in for good measure as needed (I just love the looks of it but the only brand of PCCF that has consistently delivered for me, Prusament, is too expensive for day to day use. And the stuff I sell doesn't require it.
PLA and ASA just print more reliably than PETG, which has a tendency to cling to the nozzle and have little pieces come off at the worst time
I keep looking at PCTG but haven't really found a good reason to justify buying it and the price difference is real.
Diese r Beitrag wurde geändert Vor 3 hours 2 mal von FoxRun3D
Veröffentlicht : 12/06/2026 9:06 pm
Posted by: @foxrun3d
There is a new mysterious Chinese manufacturer CHCKX that sells PCTG on Amazon for $20/kg. It's actually quite good (which surprises me). Their other stuff is crap though.
Now I mostly print PCTG for general purpose, PET-CF (thats PET and not PETG) for structural parts, ASA for outside and  PC-CF when I need structure + heat resistance. I really love Siraya Tech PET-CF. PET-CF is right on the edge of what can be printed on a Core One (a 290 nozzle is OK but 300-310 is better).
Veröffentlicht : 12/06/2026 9:18 pm
