PrusaSlicer Full Spectrum
This is a port of Orca Slicer CMYK Full Spectrum color mixing. It's a first version alpha. It's a work in progress. Please give it a try. I don't have a multicolor setup on my core one.
https://github.com/hyiger/PrusaSlicer/releases/tag/v0.1.0-virtual-filaments
Virtual Filaments Tutorial
Virtual filaments create mixed colors by alternating physical filaments layer-by-layer. A region painted with "Virtual T1+T2" prints with filament 1 on even layers and filament 2 on odd layers, producing a blended color appearance.
Setup
1. Printer with multiple extruders
Select a printer profile with 2 or more extruders (e.g., Prusa CORE One with MMU3, or any multi-extruder printer).
2. Load filaments
Assign filament presets to each extruder slot in the sidebar. Choose colors with good contrast for visible blending:
Slot Example Color
T1 PLA Cyan #21FFFF
T2 PLA Magenta #FB02FF
T3 PLA Yellow #FFFF0A
T4 PLA Black #000000
3. Enable virtual filaments
  1. Go to Print Settings tab
  2. Select Multiple Extruders in the left tree
  3. Find the Virtual Filaments section
  4. Check Enable virtual filaments
The sidebar will show a Virtual Filaments panel listing all auto-generated pairs with blended color previews:
T1 + T2 (50%)   [teal/purple blend]
T1 + T3 (50%)   [green blend]
T1 + T4 (50%)   [dark cyan blend]
T2 + T3 (50%)   [red/orange blend]
T2 + T4 (50%)   [dark magenta blend]
T3 + T4 (50%)   [olive/dark yellow blend]
Use the checkboxes to enable or disable individual virtual filaments.
Painting
1. Open the MMU painting gizmo
Click the paint brush icon in the left toolbar, or press N.
2. Select a virtual filament color
In the First color dropdown, scroll past the physical extruders to find virtual filament entries:
  • Extruder 1 (physical)
  • Extruder 2 (physical)
  • Virtual T1+T2
  • Virtual T1+T3
  • Virtual T2+T3
Select a virtual filament as your painting color.
3. Paint faces
  • Left mouse button: Paint with first color
  • Right mouse button: Paint with second color
  • Shift + Left mouse button: Remove painted color
  • Alt + Mouse wheel: Change brush size
Use Smart fill or Bucket fill tool types for faster coverage of large areas.
4. Slice
Click Slice now. In the G-code preview:
  • Each layer shows the physical extruder color that the virtual filament resolves to on that layer
  • Scrub through layers with the right-side slider to see the alternation
  • The legend shows physical extruder colors (the actual filaments being used)
Settings
Found in Print Settings > Multiple Extruders > Virtual Filaments:
Setting Description
Enable virtual filaments Master toggle. When off, virtual filaments are hidden and ignored during slicing.
Advanced dithering Uses ordered dithering instead of contiguous layer runs for more even color distribution. Only applies to custom virtual filaments.
Collapse same-color regions Merges adjacent painted regions that resolve to the same physical filament on a given layer, reducing unnecessary tool changes.
How it works
Layer alternation
A virtual filament with a 1:1 ratio (50% blend) alternates every layer:
Layer 0: ████ Filament A (cyan)
Layer 1: ████ Filament B (magenta)
Layer 2: ████ Filament A (cyan)
Layer 3: ████ Filament B (magenta)
From a distance, the eye blends these into a mixed color (purple).
Color blending preview
The sidebar and painting gizmo show perceptual pigment-style blended colors. This model produces realistic mixing predictions:
  • Blue + Yellow = Green (not gray like RGB averaging)
  • Red + Yellow = Orange
  • Red + Blue = Purple
  • Cyan + Magenta = Blue
Wipe tower
Virtual filament regions create additional tool changes compared to single-material printing. The wipe tower accommodates these automatically. Each layer-to-layer alternation is a physical tool change that requires purging.
Tips
  • Start with two filaments to understand the behavior before using more complex combinations.
  • Use high-contrast colors (e.g., cyan + magenta) for clearly visible results.
  • Check the G-code preview layer-by-layer using the slider on the right side. You should see the painted regions alternate between the two component colors.
  • Thin walls and small features may not show the blending effect well since they have fewer layers.
  • Print speed: Virtual filaments don't change print speed, but the additional tool changes add time. Check the estimated print time before committing to a long print.
Limitations
  • Virtual filaments can only be applied by painting faces in the MMU gizmo. They cannot yet be assigned as the default extruder for a whole object.
  • Advanced features from OrcaSlicer-FullSpectrum (height-weighted cadence, 3+ color gradients, per-perimeter patterns, same-layer pointillisme, surface bias offsets) are not yet implemented.
  • Maximum of 15 total colors (physical + virtual) due to the triangle selector's state encoding limit.
Opublikowany : 16/04/2026 4:57 am
4 ludzie polubili
RE: PrusaSlicer Full Spectrum
Next up, blending on horizontal surfaces.
Opublikowany : 16/04/2026 5:10 am
1 ludzie polubili
Disclaimer: Was this done with Claude Code? Absolutely. Could I have done it myself? Yes. Would it have taken me 2-3 months? Yes. Would I have lost interest and moved onto something else after 1 week and never finished it? Yes.
Opublikowany : 16/04/2026 2:01 pm
3 ludzie polubili
Jim Nangano
(@jim-nangano)
I've downloaded it, installed and started. For my Prusa XL, I enabled the virtual colors but cannot see the blended colors. When I bring up the painter, I can apply a virtual color, but after I exit the tool, any virtual colors disappear from the object.
Opublikowany : 18/04/2026 12:32 am
Posted by: @jim-nangano
You should create filament profiles that have the main color of the profiles set to Cyan, Magenta, Yellow and Black. Also, confirmed that the project saves and loads with the color assignment intact.
Opublikowany : 18/04/2026 12:40 am
Jim Nangano
(@jim-nangano)
That did it!
Opublikowany : 18/04/2026 1:03 am
1 ludzie polubili
That did it!
I'm making some major enhancements this weekend. Right now it's still very much a work-in-progress. I'll be adding to support to specify and RGB value and have it create a virtual filament from it.
I'll report back here when the next version is ready.
Opublikowany : 18/04/2026 1:06 am
Version v0.3.0-virtual-filaments available. Can now edit virtual filaments and give them names. Can create new ones with the Add Custom button.
Opublikowany : 18/04/2026 3:10 am
1 ludzie polubili
bssquared2054
(@bssquared2054)
First, thanks for your work on this! I'm using Ventura 13.6.7 and when I try to open your full spectrum version of PrusaSlicer (downloaded from Github), there's a slash/prohibited symbol over the app icon, then there's a pop-up that says "You can’t use this version of the application “PrusaSlicer.app” with this version of macOS".
Opublikowany : 21/04/2026 5:29 pm
Posted by: @bssquared2054
It's not compiled for MacOS 13. Only later versions. I can take a look at that in few hours.
Opublikowany : 21/04/2026 8:00 pm
bssquared2054
(@bssquared2054)
Went ahead and upgraded to Sonoma (finally!) and as you advised problem solved - thanks
Opublikowany : 22/04/2026 9:58 pm
I’m taking a break (well the AI is) on PrusaSlicer Full Spectrum until the INDX arrives. I’m also curious if Prusa will implement this for PrusaSlicer 3.0. A blog post by Josef Prusa seems to indicate this is the case.
Opublikowany : 26/04/2026 5:22 pm
1 ludzie polubili
https://x.com/josefprusa/status/2048132183005491292
Posted by: @hyiger
Opublikowany : 26/04/2026 6:54 pm
