Loading TPU on a Core One
Augendoc
(@augendoc)
I loaded some TPU into my Core One about a month ago. It tangled inside the gearbox and I had to disassemble the entire nextruder to get it out. During the loading process the tangled filament apparently destroyed the load sensor. After discussion with Prusa Chat, I had to order a new heatsink/loadsensor. That has now been installed and the Core One freshly calibrated. I am trying to load TPU again but I can't get the filament past the second filament sensor built into the nextruder head. I have tried trimming the filament to a taper, cutting it blunt, disabling the filament sensor, opening the  gate - nothing is letting me get the filament to the point where the menu says "Continue." Anyone have any tips?
Thanks.
Questa discussione è stata modificata 2 months fa da Augendoc
Postato : 08/03/2026 11:38 pm
There ought to be a warning on every spool of flexible filament - this is not easy to use - Prusa's note on p49 of your 3D PRINTING HANDBOOK doesn't leap out either ...
If you have disassembled/rebuilt the nextruder the most likely cause is a wrong nextruder idler pressure - the two spring loaded screws at the top need to be set correctly -
First heat the nextruder to the working temperature of the highest temperature filament you have used recently (tell the load procedure that's what you are loading - but load a length of scrap PLA) then purge the PLA and immediately unload it - this clears any residue from the path, all flexible filaments need this step.
Disconnect the PTFE tube from the top of the nextruder, feed the filament through the delivery tube and pull out a few extra centimeters to work with (if the pull is very difficult you may need to replace the internally worn PTFE or bypass it for this filament)  Now trim the end at 45° and try loading directly to the nextruder.
Repeatedly try loading the TPU, adjust the idler pressure between each try - turn both screws by the same amount and keep careful count of the turns in case you have to go back - at this stage we don't know whether the idler is too tight or too loose so you might have to try both ways ... between each apparently successful try open the idler and check the filament is following the correct path.
Finally reconnect the tube and start your print.
Postato : 09/03/2026 12:45 am
Conrad
(@conrad-2)
RE: Loading TPU on a Core One
If you can't get past the second sensor, there's a mod that replaces the spring with opposed magnets to get the force down. I don't see why using a weaker spring wouldn't also work. I'll probably try that at some point. I've printed TPE-83A by just pushing it straight into the Nextruder with the Teflon tube removed and it did go past the factory sensor with no mods. I'd expect little trouble with TPU-95, but we've got some TPU-70-something at work that I suspect I could never print without extensive modification of the Nextruder, basically all new parts surrounding the gear and bearings.
Postato : 09/03/2026 3:14 am
Augendoc
(@augendoc)
What a pain in the you-know-what. I never had any problems printing TPU with my Mk4S. I’ll look for the magnet mod.
Postato : 09/03/2026 3:44 am
DMartin
(@dmartin)
Posted by: @augendoc
Thanks.
Had the exact same problem with my CoreOne first time I tried TPU-95A. Eventually managed to get it to work, but still tricky. HOWEVER .. the CoreOne+ upgrade is the business and TPU-95A now goes in easily, first time.  I recommend it. The one thing I have learned about TPU-95A (Prusa's) is that it's VERY sensitive to what was previously printed, esp PETG.  If you don't purge lots, and I mean lots, the first part of the TPU print is liable to ooze and be stringy.  Yes I do keep my filaments dry!
Postato : 12/03/2026 7:46 pm
1 persone hanno apprezzato
JohnBirdlebough
(@johnbirdlebough)
have core one, works great for PLA and PETG, got some TPU today.  loaded, printed short while, then clicking in the nextruder starts, and nothing works after that.  So few questions.  Box says 190-230C bed 60C.  I did 230,220,210 with bed 60, if it came out the stock 0.4 nozzel it would at least stick on the bed.  problem is nextruder, took it apart, did a normal pm, noticed TPU coiled up inside.  Suspect filament sensor is causing problem, the tension of the two springs.  Normally they work perfect for over 150 1kg spools of pla, petg.  I do preheat to 37C and 15% RH in the COREBOXX spool box.  Do I need to freeze the TPU to get it to load same as PLA, or constandly loosen the two tension screws.  Thanks for any suggestions.  J
Postato : 15/04/2026 2:26 am
Posted by: @johnbirdlebough
What kind of TPU? Is it 95A or something softer?
These mods can help with printing TPU: https://www.printables.com/@hyiger_2009121/collections/2834525
Postato : 15/04/2026 3:43 am
