How to make a filament usable on all Printers???
Bytor
(@bytor)
A question for all you PrusaSlicer experts out there. How do you make it so that a filament profile, which is included with the PrusaSlicer configuration wizard, is available for ALL printers and profiles? I am going to be printing with some Taulman Bridge filament and knew that it was in the PS Wizard filament profiles. I selected it, and added it to my PS configuration.
My printer configuration is modified MK4S w/ MMU3 and the Taulman doesn't show unless I select a MK4 IS printer profile... this is despite that in the Filament Dependencies ALL is checked off for Compatible Printers and Compatible Print Profiles. I even tried unchecking these parameters and manually selected the printers and profiles that I wanted. Made sure I saved my changes. The Taulman filament still doesn't show. I even tried closing and re-opening PS.
I have a few other filaments I plan on printing with in the near future and don't want to have to struggle to get a filament to show up under a specific profile. All filaments should be available under all printers and profiles...
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Veröffentlicht : 14/06/2026 2:55 pm
3d0zer
(@3d0zer)
RE: How to make a filament usable on all Printers???
Hello Bytor,
I have never done it an no experience, but can you just not export it and import?
Just a guy with a Core One L on a 3D Journey
Veröffentlicht : 16/06/2026 5:02 am
REB
 REB
(@reb-3)
On the filament tab for the filament in question select Dependencies and check all for compatible printers and compatible print profiles.
Veröffentlicht : 16/06/2026 3:42 pm
https://forum.prusa3d.com/forum/prusaslicer/how-to-make-prusament-and-other-filament-presets-to-other-printers/
Veröffentlicht : 16/06/2026 5:33 pm
Bytor
(@bytor)
Thanks REB and NEOPHYL. I wound up saving a copy of the Filament profile and removing the "Compatible printers condition" under the Filament Dependencies. Now it shows up under all my printer configurations.
I just think this whole process is asinine and is misleading with the current setup. For instance under "Compatible printers" in the Filament Dependencies the default is that ALL is checked, the same with the "Compatible print profiles". However, if that was the situation then we wouldn't need to go thru this process to get filaments showing up under our printer configuration of choice.
- 3rd PRUSA i3 MK2S
Veröffentlicht : 17/06/2026 2:28 am
