Help diagnose print/filament issue
Brian Parfitt
(@brian-parfitt)
Hello all. I'm looking for some help identifying is happening here. I am printing Polaymaker PLA pro on my Core One+.
It looks like I am getting some artifacts at directional changes.. i.e close to the edges of my print, around holes etc.
I'm using print settings from Polymaker:
Nozzle temp: 215 (first layer), 210 all others
Bed Temp: 60
Max volumetric speed: 15 mm3/s
Retraction length: 1 mm
Retraction speed: 30 mm/s
Any idea what is happening here?
Thanks in advance!
Publié : 20/04/2026 1:12 pm
jan.d.slay
(@jan-d-slay)
RE: Help diagnose print/filament issue
That's perfectly normal if the flow rate is too high.
You'll need to use calibration tools to figure out how to adjust your filament
https://github.com/hyiger/filament-db
https://github.com/hyiger/PrusaSlicer
Do you know where to adjust the flow rate in the slicer?
Publié : 20/04/2026 5:40 pm
Posted by: @brian-parfitt
Hello all. I'm looking for some help identifying is happening here. Thanks in advance!
What nozzle are you using?
Publié : 20/04/2026 5:42 pm
Brian Parfitt
(@brian-parfitt)
Prusa High Flow .4mm nozzle that came with my Core One.
Publié : 20/04/2026 6:19 pm
Brian Parfitt
(@brian-parfitt)
Just a little more follow-up on this item. I see that I can tune my extrusion multiplier and have found a video which demonstrates generating a calibration cube to calculate a multiplier. Seems like the next thing I should try out. Am I headed down the right path here?
Thanks again for the tips!
B
Publié : 20/04/2026 7:24 pm
