xBuddy Box Ventilation
SweetRide
(@sweetride)
I have my mk4S in an enclosure. I have the power supply mounted outside of the enclosure to theoretically extend its life .
Does anyone add a fan to help ventilate the xBuddy box? Am I overthinking it? That tends to happen regularly.
Postato : 07/10/2024 4:19 pm
Rainer
(@rainer-2)
RE: xBuddy Box Ventilation
I found this
Postato : 07/10/2024 6:47 pm
1 persone hanno apprezzato
SweetRide
(@sweetride)
Posted by: @rainer-2
I found this
I looked at that and it has me inspired to make a new cover with a 40mm fan setup at the bottom, and a simple vent at the top. The idea is to just have air moving through the box. I'm not doing super hi-temp printing. The thought is to make sure the box itself isn't soaking too much in it's own heat.
Postato : 07/10/2024 7:29 pm
SweetRide
(@sweetride)
I made a cover plate that accepts a 40mm fan. I tapped into the printers 24v supply to run it. Moves a nice amount air.
https://www.printables.com/model/1037406-mk4s-xbuddy-cover-for-40mm-fan
Postato : 12/10/2024 3:58 pm
