5 Ghz Wifi mod/replacement chip?
Brandon
(@brandon-4)
I've got a 5 Ghz-only wifi network. The MK4S's wifi chip is 2.4 Ghz only. I'm wondering if maybe the chip is using some standard port and if there is perhaps a third party chip out there with 5 Ghz networking that I might be able to swap it out with. Anybody know?
Posted : 05/03/2025 7:10 pm
Walter Layher
(@walter-layher)
RE: 5 Ghz Wifi mod/replacement chip?
I am not sure if there is a drop-in replacement chip for 5 Ghz. But you could use a travel router like the  TP-Link TL-WR902AC (about 25 Euro). Then you can use an ethernet patch cable between the router and the printer and configure the printer like it was connected to ethernet.
Posted : 05/03/2025 8:22 pm
strjan
(@strjan)
Afaik, there is no ESP module 5ghz WiFi. They are internet for IoT, where reach is more important than speed. And it is same frequency as Bluetooth....
While back, I had a WiFi extender from TPlink, which has a LAN port. The extender suits in power socket, some have passthroug for the power. Similar solution to previous post.
Posted : 08/03/2025 3:51 pm
