Yet Another PETG Weirdness Question
JOHNE
(@johne)
I am printing a set of large pieces (rotary tool workshop) that appear to be reasonable quality models.  They printed fine in PLA but I decided to redo them in PETG for sturdiness.  No I am having problems I've never seen before.
The first attempt printed 90% of the model and then went spaghetti for the last 5-6 layers.   I was out of filament so I reloaded with a brand new spool of Prusament Black and resliced using the Prusament PETG 1.5 profile.  The first few attempts went spaghetti right away so I scrubbed the silk plate and retried.  Got a few layers down (as you can see from the attached photo) and then it went spaghetti.  My only theory is that the nozzle is worn out (?)   It's like the Prusa Brass High Flow nozzle is getting some kind of flow problem in mid-print??
Hoping somebody has a better diagnosis.
Publié : 20/12/2025 3:55 pm
LarGriff
(@largriff)
Looks like a layer shift occurred.  I, too, print a lot of PLA and a lot of PETG.  With PETG, you can get a lot more blobs building up on the nozzle.  Occasionally, those blobs attach to the part, then harden, and cause a subsequent crash.  It seems to help by increasing the printer setting for retraction from 0.7 to 1.4.  YMMV
Also, make sure you have good adhesion to the bed.  PETG tends to curl more than PLA so it’s imperative to have a clean plate.  If it curls too much, again you have a crash.  Satin works best for me, but textured can work well, if it’s really clean.
Ce message a été modifié il y a 5 months 3 fois par LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 20/12/2025 8:47 pm
Walter Layher
(@walter-layher)
RE: Yet Another PETG Weirdness Question
It also can help to slow down the print a bit with the speed control on the printer. Better one successful print at a little slower speed than several failed fast prints. 🙂
I have found that the input shaping moves the nozzle a bit too fast and abrupt sometimes and slowing down the print helps in this case. This is very model-specific.
Publié : 20/12/2025 9:00 pm
JOHNE
(@johne)
After I got the same symptoms using PLA I was sure it was a mechanical issue.  It wasn't what I expected (although I should by now).  The d*mn hot end had a piece of melted plastic behind the boot and the whole block had worked loose.  I was unable to recover the heater block with the thermistor intact.  Still trying to get that loose but fortunately I always keep a spare assembled heater block (which I can only get from Prusa because their so-called reseller in the US never has it in stock).
I am growing weary of the hot end on the MK4 getting stuffed up with plastic and completely wedged.  Not only do you have to monitor the printing but I guess I am going to have begin inspecting the hot end carefully any time there is a bad print.  BAD DESIGN!
Publié : 22/12/2025 12:01 pm
