Vertical waves on MK4
kingof7eleven
(@kingof7eleven)
Hello, after some work with the correct settings, I am actually very satisfied with the prints from my Prusa MK 4.
However, unfortunately it makes these unsightly vertical waves as shown in the photo.
Strangely enough, this doesn't happen across the entire surface, but only in the lower half of the printed part.
I've already checked everything mechanically (threaded rods, bearings, belts, etc.).
I'm printing with the original printer profile using Input Shaper.
Does anyone have any advice?
Perhaps the speed is too high, despite the original profile remaining unchanged.
Thanks!
Opublikowany : 08/12/2025 5:02 am
jan.d.slay
(@jan-d-slay)
RE: Vertical waves on MK4
Have you checked the belt tension?
Opublikowany : 08/12/2025 6:00 am
kingof7eleven
(@kingof7eleven)
Yes, looks OK for me.
Posted by: @jan-d-slay
Opublikowany : 08/12/2025 12:07 pm
jan.d.slay
(@jan-d-slay)
Oh sorry, that didn't come across clearly on my part. I actually meant checking the belt with the Belt Tuner in the Prusa app.
Opublikowany : 08/12/2025 12:39 pm
Rob
 Rob
(@rob-25)
I had the same, tried this: https://www.printables.com/model/473119-prusa-mk4-single-layer-test-02mm and landed on an Z offset of 0.04 for my printer.
Opublikowany : 16/01/2026 8:02 pm
