Temperature or flow?
AHz
 AHz
(@ahz)
ello everyone!
I have a problem with printing some parts of the model. All the other parts of the part print without problems. I use PLA with 220/65. Settings "General PLA". Tried filament from different manufacturers. The problem remains. As a consequence, hotend touched to model and next the layers were displacement.
Thank you for any advice!
Posted : 07/03/2025 11:03 pm
How thick are those walls?
Files > Save Project as
Posted : 08/03/2025 1:15 am
AHz
 AHz
(@ahz)
RE: Temperature or flow?
Posted by: @diem
extrusion width - 0,45
box_for_prusa
Posted : 08/03/2025 8:35 am
This sort of detailed interior structure is not suited to a high flow nozzle - you have been changing a lot of parameters that suggest you are attempting to speed up printing a part with a lot of detail - almost none of the changes work with very short head movements as there is no room or time to build up to a velocity where any of them will take effect.  Thin sections close together with overheated filament are a recipe for cooling problems.
Switch to a standard nozzle and use the original presets - the part should print a lot better; if you still have issues widen the base of the inverted pyramids to increase stability.
Posted : 08/03/2025 12:51 pm
AHz and Brian liked
AHz
 AHz
(@ahz)
Thank you! I will try!
This post was modified 4 weeks ago by AHz
Posted : 08/03/2025 2:59 pm
