support material adhesion problem
hugo1411
(@hugo1411)
Hello,
i've searched the forum, but didn't find a solution for this problem
only the support material doesn' adhere. The rest works fine.
Do you have tips for me? THX
Posted : 21/04/2025 11:06 am
RE: support material adhesion problem
Hi Hugo, can you provide a copy of your project file
Prusa slicer,
File> Save Project as...
this will give you a .3mf file,
then ZIP the .3mf fila, and attach the ZIP File to your next post please
Posted by: @hugo1411
Hello,
Posted : 21/04/2025 11:27 am
hugo1411
(@hugo1411)
Here it is
Problemfile
Posted : 21/04/2025 11:30 am
Hi Hugo,
I have loaded your project file into Prusa slicer and sliced it for PETG,
this gave me a Bgcode for a Mk4 printer with MMK3
I Loaded the Bgcode into my Mk3.9 printer and tried to start a print from the LCD Panel, the printer told me that the file was not 100% compatible, which is no surprise, because my printer is slightly lower performance than  yours. (YOU have high definition X and Y motors....)   however that is not directly important, because the actual gcode instructions for movements would be the same for either printer and the printer firmware uses the appropriate steps per millimeter...
the file printed without problems by the hole.
and the supports between the top and bottom surfaces broke out reasonably cleanly.
when I removed the part from the build plate, the supports under the semi circle, broke off the model and stayed on the build plate.
so it looks like a printer issue rather than a slicing issue. the slicer uses very thin extrusion for supports, could it be that your Y Belt is a little loose and the strands of support are nor aligning on consecutive layers?
Posted : 21/04/2025 6:59 pm
miroslav.h4
(@miroslav-h4)
Just an idea: Why don't you turn the object 90° with the hemispherical handle up? In my opinion, no supports will be needed, because the printer must handle the bridging dimensions even without supports. And even the side hooks will print the same as in the original position.
Posted : 21/04/2025 7:51 pm
hugo1411
(@hugo1411)
THX for this tipps. The Y-Belt was a little too tight. I adjusted it and will try again.
Posted : 23/04/2025 1:17 pm
