Middle layer gap and some small "explosion" holes in print
Gweb
 Gweb
(@gweb)
Miembro
I've recently got an MK4S and have had several successful prints in PLA, PETG, ASA and PC Blend.
However, PETG prints had always had a less smooth finish with some layer variation here and there (by that I mean a layer that sticks out very slightly or is very slightly more recessed) but nothing that I would call a failed print or even bad quality finish.
Yesterday I tried printing a larger model and a single layer in the middle has a gap and some strings sticking out. While the rest of the model looks mostly fine (perfect base layers, quite smooth finish overall), there are some small "exploded" holes here and there with material that looks like it was expelled from the hole.
What could the cause be? Any idea how to troubleshoot the issue?
This was printed with 0.20 mm layer height structural profile, with the stock profile for prusa PETG using a brand new spool.
Este debate ha sido modificado el hace 9 months por Gweb
Respondido : 01/12/2024 11:58 am
Gweb
 Gweb
(@gweb)
Miembro
RE: Middle layer gap and some small "explosion" holes in print
If someone comes here with similar problems, this is how I solved the issue.
First I tried drying the filament but that did not improve anything. There are three things that did fix of significantly improve the results:
  • Switching to a high flow nozzle completely resolved the issue
  • Keeping the regular nozzle but slowing the print speed to 50% minimized the issue (only a few small holes, barely noticeable)
  • Switching to Prusament Galaxy Black while keeping all original settings (100% speed and the regular nozzle, stock profile) also minimized the issue (only a few small holes, barely noticeable)
So maybe the issue is linked to lower quality of this particular filament (Prusa Turquoise Blue PETG) since results with the same settings were much better with the Prusament... In any case the high flow nozzle gives perfect results with both filaments!
Respondido : 08/12/2024 9:24 am
