How to Print Multi-Material Models Without an MMU - Tutorial
[Gelöst] How to Print Multi-Material Models Without an MMU - Tutorial
Seite 2 / 2
EP91
 EP91
(@ep91)
RE: How to Print Multi-Material Models Without an MMU - Tutorial
Works great. Super good job
Thanks so much jonnieZG for sharing
Veröffentlicht : 11/05/2025 9:16 am
Marcoz
(@marcoz)
Posted by: @jonniezg
This topic has been brought on several times before, and now I'd like to summarize everything I've learned until this point and share it in form of a tutorial. Here we go.
Overview
The idea is to print multi-material models without an MMU by using the M600 command (manual filament change), which prompts you to change the filament manually whenever a filament or color needs to be switched. For larger models, this would be a tedious process, but for printing text on a horizontal plane or a multi-colored emblem, this method is ideal.
Unlike adding a filament change at specific layers—which allows only a single color per layer and requires ensuring that the nozzle is properly cleaned of the previous color—this method mimics the MMU by using a wipe tower to clean the filament and prevent plastic from oozing.
The Principle
This is achieved by:
  1. Setting "Printers >> General >> Extruders" to the maximum number of colors you want to use (I set mine to 6).
  2. Checking "Printers >> General >> Single Extruder Multi Material".
  3. Adding "M600" (manual filament change) as a "Tool Change G-code" (along with some other settings for easier printing, which I'll explain later).
  4. Tweaking "Printers >> Single Extruder MM Setup" parameters to match a configuration without an MMU. Otherwise, you may get blobs on the wipe tower.
This method is suitable only for models where filament changes do not occur over a large number of layers, as excessive filament changes would make the process impractical. Ideal use cases include printing multi-colored emblems or models with text/signs on a flat surface.
Why This Method?
Most posts I found on this topic were scarce, had issues with blobs on the wipe tower, and were prone to human error when using more than two filaments.
This method solves these problems by:
  • Ensuring the printer tells you which color is next.
  • Keeping wipe towers clean and free of blobs.
However, this method is not useful when there are too many filament changes. What counts as "too many" depends on your patience and commitment.
How It Works
  1. The print starts with whatever filament is currently inserted in the extruder.
  2. Whenever a filament change is needed, the print pauses (beeps and moves the head to the right) until you press "Resume" on the LED screen.After pressing "Resume," watch the printer screen carefully. It will display the next color for 4 seconds (e.g., "Next color is GREEN").
  3. The head moves forward, unloads the filament, and waits for you to insert the new one.
  4. The head moves to the wipe tower, cleans the nozzle with the new color, and resumes printing.
Tip: Set "Sound: Loud" in the printer settings so you can hear a beep whenever the printer needs your attention.
Instructions
1. Creating a New Printer Profile
  1. Copy your regular printer profile, e.g., "Original Prusa MK4S HF0.4 nozzle", and save it as "My Prusa MK4S HF0.4 nozzle MMM".
    I use "MMM" as an acronym for "Manual Multi-Material".
  2. Set "General >> Extruders" to 6 (or the maximum number of colors you plan to use).
  3. Tick the checkbox "General >> Single Extruder Multi Material".
  4. In "Custom G-code >> Tool Change G-code", enter the following code:
{if previous_extruder != -1}
M601 ; Pause
M400 ; wait until all moves are completed
; color notification
M117 Next color is {
  (extruder_colour[next_extruder] == "#00FF00" ? "GREEN"
  :(extruder_colour[next_extruder] == "#FF0000" ? "RED"
  :(extruder_colour[next_extruder] == "#FFFF00" ? "YELLOW"
  :(extruder_colour[next_extruder] == "#FFFF40" ? "YELLOW"
  :(extruder_colour[next_extruder] == "#0000FF" ? "BLUE"
  :(extruder_colour[next_extruder] == "#000040" ? "NAVY"
  :(extruder_colour[next_extruder] == "#80FFFF" ? "CYAN"
  :(extruder_colour[next_extruder] == "#00FFFF" ? "CYAN"
  :(extruder_colour[next_extruder] == "#00D0FF" ? "CYAN"
  :(extruder_colour[next_extruder] == "#0080FF" ? "LIGHT BLUE"
  :(extruder_colour[next_extruder] == "#FFFFFF" ? "WHITE"
  :(extruder_colour[next_extruder] == "#000000" ? "BLACK"
  :(extruder_colour[next_extruder] == "#999999" ? "GRAY"
  :(extruder_colour[next_extruder] == "#808080" ? "GRAY"
  :(extruder_colour[next_extruder] == "#E0C872" ? "KHAKI"
  :(extruder_colour[next_extruder] == "#FF8000" ? "ORANGE"
  :(extruder_colour[next_extruder] == "#FF00FF" ? "MAGENTA"
  :(extruder_colour[next_extruder] == "#800080" ? "PURPLE"
  :(extruder_colour[next_extruder] == "#8000FF" ? "PURPLE"
  :(extruder_colour[next_extruder] == "#FF6600" ? "ORANGE"
  :(extruder_colour[next_extruder] == "#800000" ? "BROWN"
  :(extruder_colour[next_extruder] == "#804040" ? "BROWN"
  :(extruder_colour[next_extruder] == "#400000" ? "BROWN"
  :extruder_colour[next_extruder]
G4 S4 ; wait 4 seconds
M600
{endif}
Important: Make sure to add at least one empty line after {endif}!
This code reads the filament color set for each extruder ("Extruder N >> Extruder Color") and displays its name on the LED screen. The listed colors are the ones recognized, so use only these colors in PrusaSlicer settings to get meaningful hints like "Next color is RED" instead of "Next color is #FE150A".
2. Configuring "Single Extruder MM Setup"
Set the following values:
  • Cooling tube position: 65 mm
  • Cooling tube length: 15 mm
  • Filament parking position: 15 mm
  • Extra loading distance: -17 mm
  • Purging volume: 100 mm³
Notes:
  • A cooling tube position is distance from the nozzle where the filament is retracted to cool down. Values above 65 mm may cause jams, while lower values create blobs.
  • The cooling tube length is how long the filament can move in the cooling tube. I found 15 mm to be the sweet spot.
  • The filament parking position is how much the filament is retracted before the pause occurs. Values lower than 15 are likely to cause oozing, and higher values will cause the filament to exit the nozzle tube and jam.
  • The extra loading distance, combined with the value in filament parking position ensures that filament stops exactly 2 mm from the nozzle to prevent oozing.
  • The purging volume is set lower than the default 140 mm³, as the filament is purged manually during filament change.
Adjust "Plater >> Purging volumes..." for specific color transitions, e.g.,:
  • White to Black: 20 mm³
  • Black to White: 80 mm³
3. Preparing and Printing Models
  1. In your favorite CAD software, export all parts grouped by color into separate STL files.
    Example: All white parts in one STL, all black parts in another, etc.
  2. Drag all STL files into PrusaSlicer using your MMM profile.
  3. When prompted, select "Import as a single object with multiple parts."
  4. Assign each part to the corresponding extruder.
    * Set each extruder color to match the actual filament.
    * Use only the colors listed in the G-code section for accurate notifications.
Alternatively, you can use manual multi-material painting in PrusaSlicer or apply text modifiers to objects, assigning to each a corresponding extruder/color.
This method provides a way to print simpler multi-material models without an MMU, using manual filament swaps while maintaining clean prints and minimal filament waste.
Happy printing!
@jonnieZG
I have done this manual for the Core One.
When I start the print it tells me that not the right filament is loaded. Of course I looked three times, but in Prucaslicer I set all to PETG and I loaded also PETG.
After skip that message it starts working great, but the filament changes are not good.
It stops printing and the Z-axis goes down, then it stops. I had to push on resume, the extruder goes to his home position and then I have to remove the filament, but that stucks for two times. I had to loose the extruder and take all the mess out manual.
Is this manual also meant for the Core One? Or is it just for the MK4(s)?
What do I have to change to let it work for the Core One? The way it works I like it, but not the result (on this moment).
I hope you can help us?
Veröffentlicht : 22/07/2025 11:40 am
Nicholas S - StJ
(@nicholas-s-stj)
Mitglied
I'm getting this error when entering your custom Tool Change G-Code. If I leave it out, the file slices fine. Any help would be appreciated.
Veröffentlicht : 08/12/2025 9:09 pm
jmacek
(@jmacek)
Mitglied
Posted by: @marcoz
Overview
The Principle
Why This Method?
How It Works
Instructions
M601 ; Pause
M600
{endif}
Notes:
Happy printing!
@jonnieZG
I believe this is a known issue, you just hit "OK" to continue the print if the filament is correct. Works for me on my core one.
@derrick-barra had encountered the issue with two PETG colors, but I think it will happen for any filament type of two or more colors ( https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3980).
As an aside - my core one does not "beep" on pause. Maybe a setting i'm missing, my sound is set to loud, but other than that MMM works fine.
Works great though other than that!
Veröffentlicht : 01/01/2026 4:31 pm
Manuel
(@manuel-5)
Mitglied
This method allowed me to print a multi-color print on my Prusa Core One+, thanks!. I'd like to share my experience with others because he humans have a tendency to oversee things 🙂
I set it up as it is described on the first message of this thread. Later, I updated the Filament Parking Position and Extra loading distance to the safest values indicated by JonnieZG: 15 and -17 respectively.
On my first attempt, I had the message "A filament specified in the G-CODE...". I checked on the slider that the color for the first layer was loaded on the printer and set as 1 or "default" on the slider. Then, I just clicked "OK"
When it was time to change filaments, the printer moved the bed and stopped without beeping. Then I pressed continue, the bed moved again and the head went to the origin, then it started beeping and retracting filament. I changed the filament and it was purged as in any filament change. I did not get any message about "it is time for color XXX". After finishing the filament change, it purged some more filament on the wipe tower and continued the print.
I do not know if the lack of message for a filament change is due to my printer model. Because I only used two colors, that was not a problem, but this method requires to keep an eye on the printer and know what color comes at what time.
Veröffentlicht : 02/01/2026 6:03 pm
Manuel
(@manuel-5)
Mitglied
During my prints I could not change the filament. It got stuck, and I had to open the idler spacer to remove the broken filament (opening the top of the Core One, unscrew the PTFE fitting, cutting the filament and using pliers to get the stuck piece).
This is how it looks:
Can this issue be solved tweaking some of the parameters or is it a filament problem (it happened with two different colours)?
Veröffentlicht : 06/01/2026 7:27 pm
BeeMac
(@beemac)
I was getting jams and filaments like that.  I reduced the cooling tube position to 61 mm and it's working fine now.
I have a MK4S running firmware 6.4.0
Veröffentlicht : 09/01/2026 6:15 pm
Manuel
(@manuel-5)
Mitglied
Thanks! With this values no jams happened! I tried a small print where colours where changed 4 times and every change went smooth 🙂
Veröffentlicht : 10/01/2026 10:52 am
nwk23
(@nwk23)
Mitglied
I've been having jamming issues, but not consistantly. It will do the first 2 layers, but then on the 3rd or 4th layer, it will over extude a glop of filament into the wipe tower, then retract, advance, make horrible grinding noises, repeat, and complain of a filament jam.  I remove the filament, no signs of debris, trim the end, insert and purge just fine, then it goes back to the purge tower where it makes horrible grinding noises, and complains about a jam, only for it to feed just fine in the purge cycle.
In 2 out of 3 prints, this repeated until there actually was a bit of filament jamed in the feed and I had to pull the nozzle to clear it.  In the third case, I was able to nurse it along until it was past the multi color part of the print.
Any thoughts?
Veröffentlicht : 16/02/2026 2:33 pm
Loic R
(@loic-r)
Mitglied
MERCI, MERCI, MERCI !!!
Cette tour de purge fonctionne enfin 🙂
Veröffentlicht : 04/04/2026 10:52 am
MagooF16
(@magoof16)
Mitglied
This is a great tutorial but I am running into a problem where after the filament change the nozzle returns to where it stopped the print but nothing gets extruded for a centimeter of nozzle travel or so. This leaves gaps/voids in the path at the beginning of the new color until material starts getting deposited again. Is anyone else having this problem or have I missed a crucial step? I am not using a wipe tower since the workaround for single-extruder multi-color printing suggested by Prusa specifically calls for it to be disabled. Thanks for any help!
Veröffentlicht : 17/04/2026 11:21 pm
Träd-E
(@trad-e)
it appears it's not possible to use TPU as a second material using this method? I'm designing a part that could do very well with three layers of TPU as a hinge. TPU only shows in my normal single extruder config.
Veröffentlicht : 27/04/2026 5:26 pm
Loic R
(@loic-r)
Mitglied
J'avais le même problème que toi. En utilisant les instructions du post et la tour de purge, tout fonctionne correctement maintenant. Essaie de reprendre ce post depuis le début, tu as peut-être raté quelque chose.
Veröffentlicht : 27/04/2026 5:32 pm
Caveat: I haven't used any of this tutorial but I have used the precursors which, as @loic-r hinted, I linked near the start of this thread.
The method is first to configure your printer for TPU - usually this means carefully setting the extruder idler.  Then find a filament that is OK with being printed at whatever temperature your TPU requires - then slice both/all of the filaments as TPU and print very slowly.
Be aware that not all filaments stick well to TPU and you may have to try two or three to get a good combination or else design the interface with an interlock to keep them together.
Veröffentlicht : 27/04/2026 10:19 pm
Seite 2 / 2
