Can you print TPU over a PLA or PETG raft?
MVH3032
(@mvh3032)
I am using a MK4S with MMU3 in enclosure. I want to print some TPU sleeves for some brackets. I wish to avoid using the MMU3 with TPU to avoid the risk of gumming the mmu up and all the maintenance it will then need. So I intended switching to no MMU mode and feed the TPU direct to the Nextruder manually. I thought I could make my life simpler by using a PLA raft to remove the TPU more easily but cannot see a way to do it. I know I can print the raft in PLA and then trigger a pause at the end of that layer so I can swap out the PLA with TPU (like doing a manual colour change) but that will still leave the printer using the PLA settings. Is there a way of getting it to switch to TPU settings at that pause. Can I do it by telling prusaslicer the printer has two extruders and telling it to switch extruders at that point??? (note if I do that by changing the printer settings in prusaslicer to two extruders and tick the single hotend box, The TPU profile is blocked).
Am I seeking the impossible here?
Posted : 16/12/2025 12:13 am
strjan
(@strjan)
RE: Can you print TPU over a PLA or PETG raft?
There is a thread describing how to set Manual Multi material printing. Search the forum for MMM. I think it should enable also different materials.
Other than that, you can set different temperatures for different parts of print/layers. For other settings, I would search modifiers.
Posted : 18/12/2025 10:24 am
strjan
(@strjan)
Here you are: https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-how-do-i-print-this/how-to-print-multi-material-models-without-an-mmu-tutorial/#post-734746
Posted : 18/12/2025 10:27 am
