Bump on cylinder print
Jean Paul Beerens
(@jean-paul-beerens)
When a print a round object, I get a bump on them. This simple hollow cylinder has it on the inside and outside. What is causing that?
$fn=128;difference(){cylinder(h=50,d=50,center=true);cylinder(h=51,d=40,center=true); }
Printed a 50% as I just needed a small one.
Napsal : 25/10/2025 12:48 pm
It's your seam, the point at which the printer changes layer(s).
Napsal : 26/10/2025 3:29 am
mnentwig
(@mnentwig)
RE: Bump on cylinder print
Print settings, "Advanced", "Seam position": Change to e.g. "Random". This gives many random little dots on the surface (seam needs to go somewhere).
Napsal : 26/10/2025 7:30 am
