2mm layer height with Prusa mk4s
Dávid Godzsák
(@david-godzsak)
Miembro
I saw some 3D printed pieces in a museum shop that had a super large extrusion width and height. I found a youtube short about something like this. I was wondering if I can reproduce this on a Prusa mk4s.
Do you think I could achieve let's say a 2mm layer height, and extrusion width on my prusa?
  • Could you recommend a nozzle for that?
  • Would PLA or PETG work for this project?
  • What should be my material flow, extrusion width, extrusion height, layer height settings, print speed? Or at least some guidance for where I should start and I could fine tune it from there.
  • Something that's interesting in the video is that it does not even seem to touch the previous layer, it just falls on it. I wonder if it's even achievable to get good layer adhesion, or would that mean I need to set my fan settings below 100% if I choose PLA for this?
  • Anything else to consider?
I uploaded an image of what I have seen in the museum, I think this is a bit different than the video, the layer height is small and only the extrusion width is large
Respondido : 23/01/2025 2:14 pm
scustom
(@scustom)
RE: 2mm layer height with Prusa mk4s
I am just guessing, but my thoughts are no.  To get a layer hight if 2mm you need a nozzle larger then 2mm and prusa slicer only goes up to .8
The filament is only 1.75mm
Respondido : 07/02/2025 3:04 am
