Y axis Self calibration Failure
Hi, I recently got a printer and when I tried to calibrate it the x axis passed but the y axis on the bed seems to fail each time the bed moves inward toward the display. I’ve tried adjusting belt tension using the belt sounding tool and adjusting the two bearings to be closer or aligned in the pocket. Hasn’t helped.
Postato : 24/02/2025 7:00 am
RE: Y axis Self calibration Failure
some people report that adding a small spacer at the front of the left hand smooth rod, resolves this issue.
Maybe moving the bearings on the left side, slightly further apart would achieve the same result.
Postato : 24/02/2025 10:21 am
