Weird Texture on Side and Top of prints
Hyatt Brandenburg
(@hyatt-brandenburg)
Why does this keep happening? Support keeps giving different answers
This topic was modified 1 year ago 2 times by Hyatt Brandenburg
Posted : 28/12/2024 8:58 pm
The top layer ripples are symptoms of warping or poor adhesion of the first layer - throroughly clean the print-sheet and maybe add a brim.  Make sure you are not printing in a draft.
The sides might be affected by the same cause or they may be somthing else ... fix the warping first and come back with more pictures if problems persist.
Posted : 29/12/2024 1:28 am
Hoof Hearted
(@hoof-hearted)
RE: Weird Texture on Side and Top of prints
Diem's explanation is mostly likely correct I feel. You've got too much filament which is being pushed around. If you think your adhesion is ok. Try reducing the Extrusion Multiplier in the filaments section of PrusaSlicer.
Posted : 16/01/2025 11:34 pm
chmax
(@chmax)
don't you guys think it could also be a problem with the belt tension?
Posted : 22/01/2025 10:32 am
Side ripples might be, there may have been more than one cause - but the OP hasn't returned so presumably he has a fix.
Posted : 22/01/2025 10:49 am
Hoof Hearted
(@hoof-hearted)
I don't think it's belt tension. I've seen this rippling on my own prints. My belt tension was correct. The fix was to reduce the extrusion multiplier.
I've a couple of occasions when the nozzle crashed into these ripples causing the stepper to briefly stall. This caused an axis shift on the model.
Posted : 22/01/2025 11:22 am
Brian
(@brian-12)
I agree with @diem. I've seen this before especially on ASA when the part warps. It's happened to me a few times over the years.  It ends up looking similar to when your nozzle is too close to the bed on the first layer.
That's why it's only near the corners because they lifted off the bed.  It must not have happened until near the final layer, hence the distorted to layer.  More often then not the part warps long before the top layer and you only see distortions on the side of the part.
Posted : 22/01/2025 2:10 pm
