suppression probing points before print
looka
(@looka)
hello and sorry for my english, i'm an old italian...
i would to suppress probing points before the print. isn't possible? anyone is so gentle to teach me how? thanks a lot
Posted : 01/02/2025 4:57 pm
RE: suppression probing points before print
You can remove the G80 code from the start gcode in:  Printer Settings > Custom G-code
but the printer will not have an updated level map of the build sheet so first layer errors may cause many prints to fail.
Posted : 01/02/2025 6:11 pm
You really don't want to skip that step. With newer versions of firmware the printer only probes the areas necessary.
Posted : 02/02/2025 1:57 am
looka
(@looka)
thank you for the answers. i will try to explain me. i’m starting to  do some  reverse print so i need to change the color and restart printing from the plate. for to do this i use two files. when the first printing file ends i change the filament and i start the second. this one starts to print from the plate. if it start probing the nozzle crash against the first print. so i would no probing and  purge too… i hope to be clear amd sorry again for my english…
Posted : 02/02/2025 7:23 am
hkkkh
(@hkkkh)
Could you please tell me specifically how to remove the G80 code?
Posted by: @diem
Posted : 10/09/2025 2:49 am
If you need to ask that question then you shouldn't try it.
Instead, take a look at these threads which probably meet your needs by a slightly different method:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Later summary: https://forum.prusa3d.com/forum/prusaslicer/looking-for-help-in-a-file-on-the-slicer-anyone-have-the-knowledge-to-assist-me
Posted : 10/09/2025 2:47 pm
looka
(@looka)
Thank you very much, I solved it
Posted : 11/09/2025 3:27 pm
Tim
 Tim
(@tim-21)
Posted by: @looka
You can also do this using a filament color change command in Prusa Slicer ...
https://help.prusa3d.com/article/color-change_1687
Posted : 11/09/2025 7:36 pm
