Noise on x axis new to me MK4S
AStasunas
(@astasunas)
IMG_1427
I just got a new to me MK4S that upon inspection I noticed it must have been a kit as several bolts were loose or even missing. But I have a noise which I believe is x axis related which you can hear in the above videos. I adjusted the belt tension but no change. It seems is is a vibration within the extruder assembly. Any ideas? Thanks in advance.
Opublikowany : 20/03/2025 4:16 pm
Alejandro Maestre
(@alejandro-maestre)
RE: Noise on x axis new to me MK4S
The movement of the x-axis belt is really strange. It should not be moving like that, is the bearing aligned correctly?
Opublikowany : 21/03/2025 1:51 pm
AStasunas
(@astasunas)
I will check. Thanks
Opublikowany : 21/03/2025 7:18 pm
iftibashir
(@iftibashir)
Check belt is properly around both pulley's.
Check the pulley's are also properly aligned each end - the belt should be completely straight without any bend/curvature at all. Look like it's a little off on the motor side (left). Once confirmed and re-seated, re-test tension.
--> MK4 - MK4S - MINI+ - MMU3 - Accelerometer Guide - BambuLab A1 Combo <--
Opublikowany : 21/03/2025 8:02 pm
