MK4S +MMU3 + 6.40 Alpha FW - Stuck at Reloading Filament - 99% Parking
Strona 3 / 3
dbv
 dbv
(@dbv)
RE: MK4S +MMU3 + 6.40 Alpha FW - Stuck at Reloading Filament - 99% Parking
From the GitHub issue:
FYI: The fix will be included in the next firmware release. Please understand that testing of new firmware takes a while. The MMU can be used on the MK3.5/S, MK3.9/S, MK4/S, CoreOne and CoreOne L so testing all these possible combinations takes a while.
Opublikowany : 27/02/2026 12:33 pm
linuxknight
(@linuxknight)
This is still happening in 2026.  Glad I found this post.  Will try and downgrade to the earlier FW.  I wish I could get the filament back that I've wasted trying to get this print to complete.
500g of wasted Grey PLA
Opublikowany : 01/03/2026 6:27 am
LarGriff
(@largriff)
Posted by: @dbv
That posting was from months ago with no indication of when to expect a new release.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 01/03/2026 8:28 am
martinij77
(@martinij77)
Glad I found this… I’ve been having the same issues and its been driving me mad.
Opublikowany : 03/03/2026 3:28 pm
martinij77
(@martinij77)
So I hate being the new guy and ask a question that’s probably been asked a thousand times before…but I’m not having much luck searching for an answer.
How do I change my firmware BACK to an earlier version as some of you guys have recommended?
Opublikowany : 03/03/2026 4:04 pm
Same Old Shane
(@same-old-shane)
Member Admin
@martinij77
Here is a help doc that should give you the info you are looking for;
https://help.prusa3d.com/article/how-to-downgrade-firmware-core-one-mk4-s-mk3-9-s-mk3-5-s-xl_725930
This post was modified 1 week temu by Same Old Shane
Shane (AKA FromPrusa)
Opublikowany : 04/03/2026 2:33 pm
martinij77
(@martinij77)
Thanks Dude!
Opublikowany : 04/03/2026 11:52 pm
riX
 riX
(@rix)
I had this issue today, had it in the past but it stopped happening. I noticed it only happened with one slot of the MMU3, not the others, and also saw that it purged a bit of filament before the wipe. This was with filament already loaded to the nozzle. I tried selecting yes to unload filament, even though it was the right one, and then I noticed it was set to the wrong filament type in the MMU setting. Changed that, works perfectly now.
Opublikowany : 12/03/2026 6:50 pm
Strona 3 / 3
