RE: MK4S +MMU3 + 6.40 Alpha FW - Stuck at Reloading Filament - 99% Parking
From the GitHub issue:
FYI: The fix will be included in the next firmware release. Please understand that testing of new firmware takes a while. The MMU can be used on the MK3.5/S, MK3.9/S, MK4/S, CoreOne and CoreOne L so testing all these possible combinations takes a while.
That posting was from months ago with no indication of when to expect a new release.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Glad I found this… I’ve been having the same issues and its been driving me mad.
So I hate being the new guy and ask a question that’s probably been asked a thousand times before…but I’m not having much luck searching for an answer.
How do I change my firmware BACK to an earlier version as some of you guys have recommended?
@martinij77
Here is a help doc that should give you the info you are looking for;
https://help.prusa3d.com/article/how-to-downgrade-firmware-core-one-mk4-s-mk3-9-s-mk3-5-s-xl_725930
Shane (AKA FromPrusa)
Thanks Dude!
I had this issue today, had it in the past but it stopped happening. I noticed it only happened with one slot of the MMU3, not the others, and also saw that it purged a bit of filament before the wipe. This was with filament already loaded to the nozzle. I tried selecting yes to unload filament, even though it was the right one, and then I noticed it was set to the wrong filament type in the MMU setting. Changed that, works perfectly now.
Do we know if this bug was fixed in the latest beta firmware 6.5.3?
For God's sake, if you are using an MMU unit, never, I repeat never start printing with filament loaded into the nozzle! Have the filaments ready in the correct MMU slots and let the MMU load the filaments according to the settings in the slicer! The unit is not stupid and will know how to load the filaments!
